C218 CLS63, 2011 - 2019
CLS63AMG on Forgestar CF10s
Old Jan 20, 2012 | 06:50 PM
CampioniShop's Avatar
Former Vendor of MBWorld
Check out Thomas’ Twin Turbo Mercedes AMG CLS63 shot by the amazing photographer Ronnie Renaldi Photography with 20″ Forgestar CF10 finished in Piano Black Powdercoat.
Specs
Forgestar CF10 Rotary Forged Wheels
20×9 Front
20×10 Rear
For more information:
http://www.campionishop.com/product/...0/Default.aspx
Old Jan 20, 2012 | 07:52 PM
hyperion667's Avatar
2012 CLS63
very nice photog, but these 20's look kind of big to my eyes......
but still pretty damn sweet
Old Jan 20, 2012 | 08:05 PM
Vic55's Avatar
Administrator
I think its the tire sidewalls...
Old Jan 21, 2012 | 03:34 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
First off, these are my 3rd or 4th set of ForgeStars - absolutely love the wheels / company. I think they look incredible, and they're very fairly priced. I'd recommend them to anyone.
On another note - Nitto Invos have HUGE sidewalls (these even rub they're so tall). So that's why they look a little off-kilter. I think with a shorter sidewall (Invo or otherwise), they'll look even better.
Old Jan 21, 2012 | 12:37 PM
Vic55's Avatar
Administrator
Whats the profile set up on the pics? 35 front and 30 rear?
Old Jan 21, 2012 | 06:08 PM
That sounds right, but I don't remember off the top of my head.
Old Jan 21, 2012 | 08:19 PM
diononiz's Avatar
2011 E63
I am trying to decide between 35/30 and 30/25. I am leaning toward the former to save my rims and ride qual. What are the pros/cons of each ?
Old Jan 22, 2012 | 01:41 AM
Here are my opinions:
1. If you avoid the potholes you can see, your wheels (even with 25-series sidewalls) should be ok (in my experience)
2. I would / have / will again sacrifice ride quality to ensure my tires won't rub
3. Unless you have a fitment guarantee in writing, or your tire people love you, make clearance (no rubbing) your top priority
So, I'd say go 25/30. And smaller tires never looked worse (generally)
Old Jan 22, 2012 | 02:17 AM
BenzoBoi's Avatar
Super Moderator
W221
Looks good!
Old Jan 22, 2012 | 05:44 AM
_AMG_'s Avatar
C63
Awesome looking setup!
What happened to the P40's?
Old Jan 22, 2012 | 12:31 PM
Vic55's Avatar
Administrator
If you go 20's you need/should run 30 fronts and 25 rears... this will keep the overall diameter similar or the same as the factory set up (whether you have 18's or 19's).
I run 20x9 and 20x10 255x30 and 295x25 tires on my E63.
On the CLS, which you run a wider wheel and tire, I run 255x30 and 305x25 on 20's.
But with the smaller sidewall, as mentioned, you run a greater chance of wheel bending depending on your roads.
Old Jan 22, 2012 | 02:12 PM
Thanks for the kind words everyone
They're still around - I have more wheels / tires in my shed than anyone would ever really need
Old Jan 22, 2012 | 03:52 PM
elijah's Avatar
Euro Cars Only
My very first thought!!
Old Jan 22, 2012 | 04:09 PM
2012 CLS63
no doubt....
in this picture....the tires (like Vic pointed out) are big and clunky
looking.....making it look weird to me anyway....
picture is still stunning, but this angle is weird for the wheel/tire setup
Old Jan 24, 2012 | 12:42 PM
diononiz's Avatar
2011 E63
Thanks. My problem is also tire size. I really want to run Michelin pilot super sports and they have 255/35/20 and 285/30/20 but no 255 /30 for the front. Only 265/30/20. I think these may be a bit wide. The shop I used recommended the 35/30 setup as they have run it would good success. I am running it now with some "loaner " tires.
Old Jan 24, 2012 | 12:50 PM
Vic55's Avatar
Administrator
35/30 is too tall for 20's--- your diameter will be almost an inch too high.
Old Jan 24, 2012 | 05:48 PM
diononiz's Avatar
2011 E63
Thanks for the response and please pardon my newbie question, but what are the consequences of a diameter an inch too high? I will be lowering the car.
Old Jan 24, 2012 | 09:21 PM
Possible rubbing
Old Jan 24, 2012 | 09:30 PM
threeMBs's Avatar
Only MBs - the best or nothing
Just want to confirm what 35/30 exactly mean. Are you in fact running, as a "test", 255/35-20 & 285/30-20 F/R tires? That is a 27" front diameter!!! If it is on W212 E63, then I do not see how its possible. (I know its a CLS63 board, but signature states E63).
Old Jan 24, 2012 | 09:31 PM
Vic55's Avatar
Administrator
Possible rubbing on thicker rubber is one thing Id worry about. Looks is another with the larger sidewalls. Also your speedo will be off (slower) since the rolling diameter is taller.
