C218 CLS63, 2011 - 2019
Tire size for 2012 cls63
Old Feb 17, 2012 | 06:04 PM
Mr. Happy's Avatar
2014 Lotus Evora S
I have 2 questions: Does anybody know how wide you can go with rear tires on original 19" amg rims and how wide can you go on any rims? Thanks.
Old Feb 23, 2012 | 06:45 AM
Mr. Happy's Avatar
2014 Lotus Evora S
Can anyone provide any help here? Thanks!
Old Feb 23, 2012 | 10:28 AM
Vic55's Avatar
Administrator
Well the factory wheel is 19x10- you could go 305x30x19 or maybe 315 on that wheel but it would look stupid and it would not be optimal. You would have too much overlap sidewall.
On any wheel- the max would be a 305 tire or maybe a 315 if you are not lowered but I recommend 305x25 (these scenarios would be for a 20x11 wheel)
Old Feb 23, 2012 | 03:24 PM
vdubpower's Avatar
i drive them all, fast and hard
i was just gonna post that vic knows ....
Old Feb 24, 2012 | 09:26 PM
Mr. Happy's Avatar
2014 Lotus Evora S
Many thanks for the info.
Old Feb 24, 2012 | 10:39 PM
Saeedg48's Avatar
2009 CLS63 AMG
the stock setup is really the biggest you can go on this car. 285 30 19
Old Feb 25, 2012 | 01:09 PM
ripgut's Avatar
CLS55 AMG
hi vic,
does this apply to wheels going on a CLS55 also?
Old Feb 25, 2012 | 01:14 PM
Centurion's Avatar
a car that gets very poor gas mileage.
Not exactly.
Old Feb 25, 2012 | 01:21 PM
Centurion's Avatar
Originally Posted by ripgut
hi vic,
Yes, as a matter of fact, if I recall, the C219 has a little more room out back to play with.
Also, the offset of your wheels will play a very important role in determining how wide of a tire you can mount in the rears before you start to get any rubbing on the fenders.
Old Feb 28, 2012 | 05:58 AM
Mr. Happy's Avatar
2014 Lotus Evora S
Thanks. One more thing: do you know the offset on the stock MB wheels? ET 35 or 45?
Old Feb 28, 2012 | 10:26 AM
Vic55's Avatar
Administrator
hi vic,
As mentioned pretty much- the only difference is the C219 can run an even lower offset in the rear than the C218 (2012 CLS)
Front is et37 and Rear is et47 (forged 19's)
Old Mar 3, 2012 | 10:08 AM
Mr. Happy's Avatar
2014 Lotus Evora S
Thanks! I also found out the same information in the owner's manual. I would have thought that since the front breaks are bigger than the rear breaks, the offset required on the front would be larger, but it's not the case. Why is that?
What's behind my question is that I will need to get a set of rims for next winter eventually. According to the manual, I should go with 255/35/19 for all tires but with rims of 9X19 et37 on the front (same as original) and 9.5X19 et52 on the rear (same tire size but different rim size?). I'm wondering why not 9X19 on 4 wheels so I suspect that the clearance required on the rear is needed for another reason than brake size.
Thanks for helping make my education on wheel sizes for this car!
Old Mar 3, 2012 | 12:40 PM
ripgut's Avatar
CLS55 AMG
is the offset the same for forged 20's?
thanks vic.
James
