C218 CLS63, 2011 - 2019
WONT FIT - Michelin Pilot Super Sports
Old Feb 24, 2012 | 02:28 PM
Saeedg48's Avatar
2009 CLS63 AMG
Question WONT FIT - Michelin Pilot Super Sports
getting ready for a better set of tires on the CLS63.
the stock rear setup is 285 30 19 with continentals.
unfortunately michelin pilot super sports only come in
295/30ZR19 and 275/30ZR19 in 30s
they have the PS2 and the PS "AF".
i've owned the PSS and the PS2 and personally prefer the PSS. not sure what the PS "AF"s are.
suggestions?
Old Feb 24, 2012 | 02:50 PM
_AMG_'s Avatar
C63
If 295's fit without rubbing, then I would go with that size.
How wide are the OEM wheels?
Old Feb 24, 2012 | 03:23 PM
Vic55's Avatar
Administrator
295/30ZR19 and 275/30ZR19.
suggestions?
They should fit if you are not lowered- the ET 47 in the rear allows for more room and sidewall. It may look funny though.
Old Feb 24, 2012 | 08:28 PM
mainly's Avatar
Porsche 991 GT3, 2012 cls63 Kleemann K3
suggestions?
wont fit?
who's saying they wont fit?
Old Feb 24, 2012 | 10:40 PM
Saeedg48's Avatar
2009 CLS63 AMG
295s it is! - thanks
Old Feb 25, 2012 | 03:57 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
If you go to the tire mfr's website, they outline approved wheel widths. 295 is fine for our stockers, IIRC.
Old Feb 25, 2012 | 01:11 PM
Centurion's Avatar
a car that gets very poor gas mileage.
Good choice!
I love Michelin's PSS.
Best tire I've had on a sedan...oh I'm sorry, "4-door coupe".
I've also got 295, but they're 25 series, not 30.
You'll be perfectly fine on the stocks with no rubbing issues.
Old Feb 25, 2012 | 01:23 PM
mainly's Avatar
Originally Posted by Centurion
Good choice!
i would think it would be better to go with a 295/30 in the rear - would only be 0.2" taller tire diameter than stock.
a 285/25 would be almost a full inch shorter tire than stock...
youd get probably more wheel spin? no?
Old Feb 25, 2012 | 01:32 PM
Centurion's Avatar
In Saeedg48's case, yes. He should stay with 30.
I've got aftermarket wheels.
Specifically, I'm running 295/25-21 Pilot Super Sports.
Old Feb 25, 2012 | 01:39 PM
mainly's Avatar
yeah, i definately couldnt go there myself... 295/25 = 73. 75 mm sidewall!!
must look like a rubber band on 21's!!!
what about just switching out the stock rear 285/30 for a 295/30 ?
and leaving the fronts as is.
anyone done this?
Old Feb 25, 2012 | 02:20 PM
Centurion's Avatar
That should be perfectly fine.
What will end up happening is that you'll have a slightly larger overall diameter in the rear.
285 * 30% = 85.5mm
295 * 30% = 88.5mm
Which means, you'll end up with approximately 0.2 or 0.3 inches larger in overall diamter.
Old Feb 25, 2012 | 02:32 PM
mainly's Avatar
285 * 30% = 85.5mm
295 * 30% = 88.5mm
yeah... 0.2 inches, isnt much....
should be fine
i wonder if they would put it on from the factory, i still have a couple of months left till delivery.
