CLS63TT spark plug broke
you are right, i should argue with them more on how it affected only cyl.5
i found NGK spark plugs but same heat range which is 7
The most important thing in this that Ali get her fixed under warranty
https://mbworld.org/forums/cls55-amg...ug-recall.html
why are you delaying parts of your story! Ali did the CEL come before or during the race?? i am sure you are going to say before
come on so if the plug gave up for SURE the CEL is going to not only come on and probably going to be flashing all around too
not before i raced, but maybe while i was racing and above 250, i felt the car is weak and when i slowed down , the engine was jerking i saw than CEL on .
i would have not race if it showed before
you are making us trip about whether they will hang around or fail. can you please post a pic of the rest of the plugs??
you are making us trip about whether they will hang around or fail. can you please post a pic of the rest of the plugs??im not hiding anything nor i am blaming anything.
im not that careless to race if i felt there is something wrong with my car, and it was a random race
one plug failed, and it has to do with the white ceramic small part ( same as recall issue ).
blew the engine, braked it down, call it what you like, and if i was not intrested to keep you all guys safe from having an issue, i would have not opened a thread from the begining.
car was fine 100% untill that day i raced and CEL came on with viberation, to tell you the truth, even if you drive it now or idle it, the vibration is not that bad.
so what do you think i am hiding !!
bad tune cause it ? maybe !! who knows ?
i will take pictures of the other plugs and will post them here
good we need to see how they look like, here is how my plugs look like after 7000km which would be around the same age as your plugs plus we both drive our cars hard most of the time
This is all fine since Ali posted it in a public forum (opinions have to be expected) but lets wait and see what the techs really say. The bottom line is if one mods their car, they better have the "pay to play" mentality just in case.
I wonder if some tuners are advancing too much timing---
let's wait for the pics
we all drive those plugs in our cars if I had a problem I will share it so all the others would avoid it. If you go back to your dyno thread Ali mentioned how better the AFR is with the tune, so he must have asked for advancing the timing for more power and this is the consiquenses of his interference in the tune. I hope I am wrong but you must expect the argument on all possible couses. Sorry if this doesn't make some comftable, I like everyone with the V8TT would want to know!
we all drive those plugs in our cars if I had a problem I will share it so all the others would avoid it. If you go back to your dyno thread Ali mentioned how better the AFR is with the tune, so he must have asked for advancing the timing for more power and this is the consiquenses of his interference in the tune. I hope I am wrong but you must expect the argument on all possible couses. Sorry if this doesn't make some comftable, I like everyone with the V8TT would want to know!But like i said, Id like to hear what the techs say that actually touch his car and I too hope he gets his car fixed... for free.
we all drive those plugs in our cars if I had a problem I will share it so all the others would avoid it. If you go back to your dyno thread Ali mentioned how better the AFR is with the tune, so he must have asked for advancing the timing for more power and this is the consiquenses of his interference in the tune. I hope I am wrong but you must expect the argument on all possible couses. Sorry if this doesn't make some comftable, I like everyone with the V8TT would want to know!i did not ask for more timing from the tuner or anything, i have exactly what vic has on his car. and my AFR is richer than what i had on stock tune
techs will propably blame it on the tune even if it is a fualty plug.
and yet till now they didn't report to me on what is wrong with the engine
guess they didn't poped the head or used a mico camera.
if the bore is fine i will fix it and use NGK plugs and check them every 5k
head cost 7000AED ( about $1900 ) , each valve cost 140AED ( less than $40)
so part wise will be maximum $2500, but labor wise will be Total RIP OFF.
these are the prices if i have to pay. untill now, dealer didn't take a decision if it is under warranty will be fixed.
primary check up by dealer is that for sure the valves and cylinder head is damaged, piston ring and bore seems not affected ( i hope ) because they can't see it now unless they open up the engine and double check.
micro camera shows no affect on other parts.
will keep you guys updated as soon as a hear something new
i don't know too much about engines, so what you're saying is the spark plugs caused this issues, damn that's wack..
If you unlucky it can get pinched between valve and valve seat or if squish is smaller than piece it will get stamped in to piston and sit there. I have never seen electrode damage cylinder wall, at least on motorcycle engine that I work on all the time.
Since compression is down on Ali's engine I would do simple leak down test and see where it is leaking. It will tell if exhaust valve, intake or piston. Simple test that points to problem.
