CLS63TT spark plug broke
When was your CLS built?
My uncle has the 2012 CLS63, which is completely stock. He had the same problem that you are facing.
The plugs is a common problem for the M157 engine. They were on recall and they still did not come up with something good.
Get yourself some Brisk Spark plugs. A friend of mine is running them on his Tuned M157 E63 without any issues.
First off, if you took your Rolex, opened it up and modified it and then took said Rolex back to the manufacturer and said the watch isn't keeping time correctly, what do you think they would say?
Second off I've worked on cars and been modifying cars for year and seen plenty of engine failures and part failures. Even though the picture is blurry that's a text book example of lean detonation.
I've personally replaced these faulty spark plugs and when the ceramic breaks is slides down over the electrode and causes a misfire, CEL, and the ME shuts that cylinder down.
I'm with dbasons55, nothing that is being stated here makes any sense at all. Only .8 psi above stock cannot produce the claimed performance results. I may be just a lowly service technician (who is very mod friendly) but risking my livelihood to warranty something this is obviously caused by an outside influence isn't worth it. Just remember, your wealth has no correlation to your intelegance.
Also - You mentioned you were a SA
Are you seeing a lot of 2012 AMGs coming in with bad plugs?Thanks Tri
I think what happened to you was different than what happened to Ali. Ali's plug looks like the cylinder ran lean causing the temperatures to go way up. Then the ground strap of the spark plug was cherry red from all the heat much like a glow plug. Then when the injector sprayed into the cylinder is caused the fuel to ignite before it should have causing all hell to break loose.
Rasing the boost with a flash creates higher cylinder pressures and temperatures. Which more than likely made the porcelain from the bad run of spark plugs in the early engines crack due to higher stresses. When the electrode strap is still on the spark plug it blocks the ceramic from falling off the spark plug and into the combustion chamber
The shop I work at has one of the highest concentrations of AMG's in the country and we've seen 3 cars come in with a single bad plug in each.
Seriously this is not worth getting stressed about... just let him sort it out. Obviously he is just going on information he is being given from many sources. Give the guy a break!
Thanks for the input here, the MB tech perspective is very helpful. If only you worked in my market.
Not that I will hold you to it but can you give us a sense of what the timeframe was for the bad run of plugs. My cls63 was built last week of October. I took me car to the dealer to ask about my plugs and they said that I did not need to worry on my car but freefall had issues and his was built first week in October.
I just got the Renntech flash and my tuning shop looked at my plugs before the flash and said they looked fine but I am really concerned about them given this thread. Thanks.
email us Info@redlinespeedworx.com
Looks like detonation, and the factory ECU failsafes couldn't interfere in time to save the engine. Maybe the aftermarket tune's a smidge too aggressive, or maybe it's simply a smidge too aggressive for this particular client's extreme usage.
I expect we'll get to the point where upgraded tunes for M157's require (or are strongly recommended by the tuner) a one-step colder plug install to accompany their usage. Whether it be Bosch, NGK, Denso, or whomever. I'm actually a little surprised it wasn't recommended already, given when adding this much power over a stock level, moving to a one-step colder plug to help keep cylinder head temps happy is Tuning 101.
Regardless, it is what it is... a shame for Ali to be the unfortunate R&D guinea pig here, but hopefully it results in better outcomes for others down the line. And, who knows, maybe his tuner will step up and financially help with the repair bill.
I remember when I went to school for the 278 engine they pounded into our heads that all the Spark plugs are indexed, When torquing the plugs they all sit in the exact same direction. Hence the thick copper seal washer not a crush washer.
My point is that there is no aftermarket plug that will index like the stocks!
I will call Brisk tomorrow about this to see what they think.
No, it's the 276 engine that is indexed, not the 278.
If you're in the tristate area I highly recommend them. Last time I was there they even had cars from around the country shipped to them to be worked on. I'll be seeing them next week!
i went to the dealer yesterday and took very nice pictures with HQ. lucky for me, only one exhuast valve have been chipped, ( bore, cylinder wall, head, piston ring are all fine) i took some pictures of other plugs from inside (head side, next to valves).
BUT I WILL REPLACE THEM AND TAKE PICTURES OF THEM AFTER I GET THE CAR ( just for dbasons55 sake )
the other plugs looks fine, and it was a fualty plug as they said ^_^.
SA said even if it is a fualty plug its on me because my car is tuned. otherwise it would have been on them.
tuned cars can show directly and they can see timing, AFR, and everything ( SA claim ).
funny thing he said: my tune is below the limits if my car and very strong compared to the others they checked when owners bring them for service, so even if they keep silent, they check if cars are tuned.
so it is still a safe tune. AFR is lower than stock by 0.5, maybe i will ask for a richer mix tune ( 11.2- 11.5). it should be 11.5 but maybe our weather or my DP affects the AFR to be not like Vic55.
so, parts will not cost alot, valve, gaskets, etc.
but labor is a total rip off. LOL
and the hard part is i have to wait 4 weeks for parts to reach from Germany.
thats strange, because untill now only Bosch are available in our dealer.
care to share more ?
part number !!
and the hrd part is i have to wait 4 weeks for parts to reach from Germany.
not making sense. Just wanted to add that its strange when my car was at the dealer they thought it has a Brabus piggyback
i don't think they know those details cuz i have removed the piggy back!
