C218 CLS63, 2011 - 2019
Stereo upgrade
Old Jul 26, 2012 | 09:52 PM
Lew L's Avatar
C63 Kleeman; CLS63 Renntech; Kirkham 427S/C; 308 GTB; 911T 3.0 911 cab 3.6
Stereo upgrade
Has anyone upgraded their stereo in a 2012 CLS63? I am looking to add a little more low-end for listening, not for thumping. A little more definition throughout and especially on top would be great. I don't want to lose any COMMAND functions or pull apart the dash. I also do not want to lose a lot of trunk space.
Old Jul 27, 2012 | 07:22 AM
hyperion667's Avatar
2012 CLS63
this is ironic: I was fooling with my sounds last weekend.......and realized I could control the bass and treble(like every car has lol)
actually sounds a bit nicer when I adjusted them......
I like my bass to be slightly higher than the treble......
my ears are getting old!
good luck
Old Jul 27, 2012 | 04:49 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I guess folks nowadays are not reading the owner's manuals anymore.
Old Jul 30, 2012 | 01:47 PM
Misiek4's Avatar
C63
Does anyone know where is located factory subwoofer in W218 with Harman Kardon configuration?
Old Jul 30, 2012 | 06:59 PM
phemerlein's Avatar
08 CLS63 AMG
If you look in your trunk on the underside of the rear deck you should see your (weak) 10" sub.
Old Aug 3, 2012 | 01:57 PM
Misiek4's Avatar
C63
Is it really 10"??? It sounds like crap 5".
Old Aug 4, 2012 | 11:10 PM
otakki's Avatar
I always thought I hear some kind of metal flipping sound from that area; similar to stainless steel pan flexing while heating up in the toaster oven.
By the way, that cluster under the rear deck sure take up room. A bigger suitcase would have fit if it wasn't for that cluster. I wonder what else is there in that clulster.
Old Sep 3, 2012 | 12:45 AM
charge's Avatar
2012 CLS63
So has anyone replaced the stock 10" sub and/or add amps?
I'm going to my sound guy Tuesday to see what can be done with taking any additional space.
Thanks,
Old Sep 3, 2012 | 11:19 AM
fixinbones's Avatar
2016 AMG GTS, 2015 GLA45 AMG
Let us know what you come up with.
Old Sep 3, 2012 | 11:14 PM
ecm's Avatar
ecm
2012 CLS63, 2015 GL63
I am looking into an upgrade now. I am considering removing the spare tire and putting the subs there for optimum sound. All speakers would be upgraded, new amp and processor. FYI - the BMW M3 has no spare, just that "fix flat" can you spray into a tire. The new system should be $5,000, or more if I want to spend even more on size/quality of sub woofers and amp.
Old Sep 4, 2012 | 01:38 AM
charge's Avatar
2012 CLS63
Wow! You're going full out...
Check this out:
http://www.systems-unlimited.net/ind.../mercedes-0921
Old Sep 4, 2012 | 11:49 PM
ecm's Avatar
ecm
Thanks. My stereo guy advised against having the subs in the trunk next to the spare -- that it could compromise the sound quality, and defeat the purpose, at least to some extent. Keep in mind that the B&O system Mercedes is now offering on 2013 CLS is $6,400. It's easy to spend a lot more on these aftermarket systems.
Old Sep 5, 2012 | 10:37 AM
Kelvin07's Avatar
CLS55 AMG, ML63 AMG, Cayenne S
Thanks,
Get a shallow mount Rockford 12", it's more than awesome, but the factory amp wont be able to handle the power, but Rockford also makes a sub amp that is the size of an old ipod.
I am very happy with my setup, spent like $2000 for everything, including a brand new center speaker, MS-8, amps and mids. All speakers and amps are Rockford, superb sound.
Old Sep 5, 2012 | 11:27 AM
charge's Avatar
2012 CLS63
Thanks for the info!
Where is the location of your new 12" sub? Did you take out the old sub?
Please post some pics when you get a chance.
Cheers!
Old Sep 5, 2012 | 11:47 AM
Lew L's Avatar
Has anyone here seen and heard the CLS B&O system in person?
Old Sep 5, 2012 | 12:23 PM
Kelvin07's Avatar
Cheers!
Yes, my installer took out the stock12" and put in the shallow 12", a world of a difference.
