C218 CLS63, 2011 - 2019
Lowering options for CLS63
Old Apr 4, 2013 | 08:43 PM
Vic55's Avatar
Administrator
Originally Posted by E-SICKTY3
Thanks Vic. I guess that's how the car rides then . I dropped mine with exactly one finger gap all around -- just like your CLS before, but not sure how you think about the rear comfort wise (maybe I'm not used to that many stiff rides and it is one's preference). The KWs definitely handles really well through corners and high speed driving though.
On my CLS the gap was about 1/2 finger in the rear and I didnt mind it all too much... the problem was the airmatic with me... its just allows for too much roll still even with the PP shocks. I have always not been a big fan of air and hydraulic suspensions (aka airmatic and abc)
Old Jan 28, 2015 | 07:49 AM
bryce's Avatar
CLS63
Any up to date thoughts on this subject?
On a non performance pack car, what spring set up provides the closest to OEM feel / ride - not interested in the slightest in handling improvements, just pure cosmetics.
Old Jan 29, 2015 | 05:14 PM
JPMBenz's Avatar
17 C63 S Coupe
I have a 13 CLS 550 on the Renntech setup with front lowering links. This is what a 6" Drop on the front looks like; with a 2 1/2" in the rear.
Old Jan 30, 2015 | 04:57 PM
bryce's Avatar
CLS63
Thanks for your reply. Could you clarify for me though as Im new to the w218.
Have you changed the springs in the front as well as lowering links? and has the rear been done using the Renntech module (so on factory air)?
Cheers
Old Jan 30, 2015 | 05:06 PM
JPMBenz's Avatar
17 C63 S Coupe
Cheers
In the non AMG 218; the front uses an air spring. However, it does not go as low as the rear. The Lowering Link is shorter in height which allows the car to go lower. Yes, the cars full factory suspension is still in place. I just changed the front links and added the renntech lowering module.
Old Feb 26, 2015 | 06:23 PM
dc73's Avatar
2013 CLS63
I run the KW's as i have in all my cars and yes the ride can be a little bumpy. When i 1st picked up my car it looks amazing. Hardly any tire gap but the ride was garbage. Once they raised it up a little, the ride was much better but not what i would call luxury. My main concern is when i go over reflectors or heaven forbid a railroad track, then the car shakes more than i would expect from an AMG. Price of performance and looks right.....
Old May 25, 2015 | 01:10 AM
  #32
mainly's Avatar
Porsche 991 GT3, 2012 cls63 Kleemann K3
was wondering that too. when i get my next cls im going to want to lower it. (dont car about handling improvements) but $2300 for the renntech lowering module and coilovers seems a bit much just to lower the car. then add installation and its over $3000
i was thinking for H&R springs - $300-$400, and rear links - $200-$300, about $1500 less and wouldnt you get essentially the same results?
just saw this company, they have a solution for rear lowering links for the cls63. anyone used them?
http://www.airmatic-lowering-links.co.uk/
always was hesitant to order this type of product off ebay but it IS the name of their company!
lol
http://www.ebay.com/itm/MERCEDES-CLS-CLS63-W218-LOWERING-KIT-FREE-24HR-FEDEX-SHIPPING-TO-US-CANADA-/111440614257?hash=item19f260d371&vxp=mtr
Old Aug 1, 2018 | 02:47 AM
  #33
CLS63Matt's Avatar
CLS63AMG W218 • CM7 Accord • '13 Yamaha R1
Bump. I am looking to lower my car. I found a lowering module from loweringmodule.com
http://loweringmodule.com/mercedes/cls-w218/
And wanted to see if anyone had any experience with this.
Thanks!
Old Aug 2, 2018 | 08:42 PM
  #34
CLS63Matt's Avatar
Originally Posted by Roman Morel
Of course, here you can find many threads about this module.
for example
https://mbworld.org/forums/gle-class...ule-399-a.html
https://mbworld.org/forums/w213-amg/...ng-module.html
I bought the same module here
https://www.amazon.com/dp/B07C7G3J13
You can contact free with the seller on e-mail shamaichart@icloud.com for checking VIN
Called them directly. Since our suspension is spring and air in the rear it doesn't make sense investing in this system and only for the CLS550 owners since their setup is AirMatic on all 4 corners..
Looks like I'll be resorting to Coils/Sleeves in the front and links in the rear.
Old Aug 20, 2018 | 10:48 AM
  #35
Merss's Avatar
w222
Amazon lowering module
The LoMo module 450$ work with Airmatic on all 4 corners. But about another LoMo module I don't know anything.
in that case if car has rear air suspension and front coils this device will not work
Old Aug 30, 2018 | 10:39 PM
  #36
JDMAP1's Avatar
W222 S550, W218 CLS63, W166 ML550, Titan, Sentra
I use Evoklass coilovers F and links R, both are fully adjustable to your desired height. Stiffness wise, it all depends on my suspension setting. Comfort is soft/smooth, sport is stiffer, and sport + is really stiff. I love the fact that I can play with it down to the exact mm to get it just right. You won’t be disappointed.
Old Aug 30, 2018 | 11:38 PM
  #37
try m3's Avatar
Top Answer: 1
M3, E55, cls63
Damn that looks awesome! Where did you order them from?
Old Aug 31, 2018 | 12:18 AM
  #38
JDMAP1's Avatar
got them off eBay for $650ish shipped from Ghost Motorsport which is EvoKlass out of LA area. I just a searched eBay and didn’t see any for sale. Surely you can buy it direct. If you do, make sure they send you the black rear links and not the yellowish ones. Those snapped instantly as I try to pry them off, the black ones is much much stronger.
