CLS Stage 2 vs M6 Stage 2
Good info, thanks! In your opinion how much time is saved per shift using M vs A in these cars? Also does M allow for a higher shift point vs A?
Makes me wonder why during a race anyone would switch from a faster shift to a slower one lol?
again thanks.
The press tune is supposedly the Noelle tune but 700 hp is a stretch I would think... from my research the Manhart cars are running the resistor tune cheating the ecu to think there is not enough boost, coupled with the Noelle... recipe for disaster. But they claim 700 crank.
Its hard to say how much time is saved- depends on the conditions and shift points but the car shifts faster in manual no doubt. I kind of liken it to the E60 and E63 S85 engines that ran SMGIII trannies, the drive mode was fast but running it in the S6 (or whatever) was better. The only issue with using manual mode is if you shift too early or too late you are toast- so know what your are doing LOL.
The other issue with using D mode in rollers is its not always in optimal gear for lets say..... a 50-160 run. We all know what the difference a gear makes: the difference between a win and a loss.
Just from looking at it the M5s intercoolers are huge and sit in front of the engine away from it, not in the V like someone else said. They should get plenty of cooler air away from the hot engine once it's moving. On the M157 the intercooler sits directly on top of the engine under the ECU.
