C218 CLS63, 2011 - 2019
Engineering update: Alpha Mercedes 5.5L Biturbo Intake System
Old Nov 20, 2014 | 03:38 PM
AMS_Performance's Avatar
Former Vendor of MBWorld
2012 E63 AMG
Great progress is being made with the Alpha Performance Mercedes 5.5L Biturbo Carbon Fiber Intake System! Maybe you haven’t been following this particular Alpha project, so to bring you up to speed, it began when our engineers observed and determined a number of obstructions and inefficiencies with the stock air box and intake routing on the Mercedes 5.5L Biturbo E63 & CLS AMGs. Even on a completely stock Mercedes 5.5L Biturbo vehicle, the intake design proved to be a hindrance to power production. When upgrading your 5.5L Biturbo Mercedes with tune, or exhaust system and tune, a better intake system becomes an even greater necessity since your engine will need more air to produce higher levels of horsepower and torque.
Our intake systems will consist of higher volume carbon fiber air filter box covers, carbon fiber turbo inlet pipes, intake ducts and lower air filter boxes. Carbon fiber finish will be as beautiful and flawless as any of our Alpha carbon fiber finishes (click here for example).
At the moment, we have completed our first prototype of the lower air filter box along with its custom designed air filter made specifically for this unit. Both were developed using our laser scanning ROMER arm and Solidworks, CAD software in order to increase volume and efficiency within the tight confines of the engine bay.
Lower Air Filter Box DesignThe lower air filter box was designed to be an improvement over the stock unit in every way possible. Air filter box dimensions are wider and deeper to hold more volume.
Volume increase is complemented by an intake inlet diameter that is 20% larger than the stock inlet. Our taller air filter box coupled together with a lower profile air filter design eliminates air flow obstruction at the inlet. This is present in the stock design (as shown in the image below). As you can see, the stock air filter hangs so low near the inlet, it not only creates a bottleneck in air flow, but creates unwanted turbulence that disrupts a highly desired, smooth air flow pattern. As air flow velocity and vacuum increases (when on throttle), the negative effects of this stock design are exacerbated – robbing your engine of its potential to produce power.
Air Filter DesignAs part of our intake system, we designed a free-flowing air filter that offers 41% more surface area than the stock paper filter. By increasing surface area and reducing the air filter profile, back pressure is significantly reduced. If you are worried about effectiveness, the synthetic, non-woven, multi-layer media of our filter has a MERV rating of 9 and flows with much improved efficiency over the stock unit. Each piece is also washable, reusable and requires no oiling. Should you need to replace them, a pair will cost you less than the leading name brand, high performance stock replacements.
Expected Availability
As you can see, our goal is to provide you with the very best option when it comes to upgrading your Mercedes 5.5L Biturbo intake system. Production is still a few months out and should be available by Spring, but we wanted to give you an idea of what you can expect.
Completion of the carbon fiber air filter covers, carbon fiber turbo inlet pipes and intake ducts are due up next. Be sure to check back with our blog in the upcoming months!
Old Nov 26, 2014 | 06:17 AM
XRQTOR's Avatar
2014 ML63
AMS, impressive bit of gear. Will this or will it become available for the W166 ML63
Old Nov 26, 2014 | 07:04 AM
Thericker's Avatar
V12-Biturbo
Looks great, how much HP/TQ is expected to be gained over stock?
Old Dec 3, 2014 | 04:42 PM
2012 E63 AMG
We want to actually do a before and after test before speculating but the raw prototype did great things.
90% of the kit will work just fine. We will need to make some intake ducts specific to the ML63 but we can do that once we get a car in here.
Eric
Old Feb 2, 2015 | 11:11 AM
alrasheed1991's Avatar
2011 C63AMG P31
Any updates?
Old Feb 16, 2015 | 05:34 PM
2012 E63 AMG
First prototype complete:
Old Feb 16, 2015 | 09:02 PM
Thericker's Avatar
V12-Biturbo
GORGEOUS!!!!! Way to finish it off proper like!!!!!!!!!!!
Swear evrything looks better in glossy black Carbon Fiber... If they made Glossy CF clothes I'd prolly buy them
Old Feb 16, 2015 | 09:16 PM
Rock's Avatar
Administrator
Drives Slowly
Nice looking piece Eric. Will it fit all 2012+ E63/CLS63 models?
Also, have you guys narrowed in on a price yet?
Old Feb 17, 2015 | 02:39 AM
Goletiani's Avatar
2012 CLS63AMG Kleemann K3
What is the expected outcome? It would be interesting to Dyno the car before and after installation. For instance Biturbo engine with modified turbos and stock intake vs Alpha Intake. Any info on pricing?
Old Feb 18, 2015 | 02:10 PM
trboda6's Avatar
hope it's not close to 5k which all the carbon makes me think otherwise.. :/
Old Feb 18, 2015 | 03:27 PM
Thericker's Avatar
V12-Biturbo
I bet it's not cheap nor should it be as the CF enlarged tubing runs all the way dwn the entire face of the engine leading to turbo inlets, a good deal larger than average CAI.. I'll fathom a guess it comes in @ or under $2500 though. AMS aren't price gougers like the almighty Renntech who sells CAI's in the $5k range lol
Old Feb 18, 2015 | 03:39 PM
trboda6's Avatar
$2500 is doable if dyno proves significant gains. $5k is out of the question for sure. Hopefully pricing is released soon.
Old Mar 5, 2015 | 10:15 AM
berti_00's Avatar
2016 Cls63s AMG
yah 2500 would be reasonable but I saw the renntech price and holly cow
Old Nov 2, 2015 | 12:46 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
any update on these ?
