Steering noise from 2014 CLS63 S
2014 CLS 63 S AMG / 2004 E55 AMG
When stopped or at very low speeds my car makes a strange noise when turning the steering wheel. It's impossible to describe, but it's similar to a high speed rotary tool (like a dremel), but MUCH quieter. With the radio or hbac blowing it's hard to hear. It may come and go throughout a drive, but on every drive I can hear it at some point.
The dealer also hears the sound and has replaced the front struts, strut bearings, bump stops and steering column collar (over 2 visits that spanned a week each). The noise hasn't changed...
Does anyone have this issue, or has anyone solved it?
2015 CLS 63 S
I am not sure it is the same sound/issue as mine, but when i turn the wheel at low speed, I sometimes get a clunk in the suspension. I also hear it nearly everytime I back out of the drive way. Seems to originate from the driver side.
Did/Do you have anything like that happening?
I just assumed that was the weird electro-hydraulic power steering making that noise.....Most if not all the E63s I test drove had that sound. Its usually at idle or very very little movement and you turn the wheel
@moehler saw your cross post and figured I'd chime in. I recently developed a grinding/ moaning sound heard at 5mph or less while turning. Taking it in this week and will update my results. My first thought was electronic steering problem as I see a dip in revs that almost cause a stall. The sound is persistent but the rpm dip only occurs when cold.
I am experiencing the same problem (whining noise from the steering wheel on turns at very speed AND occasional clunking noise when backing out of the driveway) . I bought my car in Feb 2015 and the problem started in October 2015 right after the first scheduled service. The car went to the dealer at least 3 times and they cannot find any problem and insist that there is no problem with the car and the noise is 'normal'. I find their answer unacceptable. Taking the car to a different dealer next week and will update once done. It is extremely annoying to hear the noise and hoping somebody on this thread has an explanation for this.
So, I was back at the dealer today (4th visit for this) and I met the tech that worked on the car. He fully agrees that the noise is still there. Although he replaced both struts and both strut bearings, he quickly diagnosed it as (again) coming from the front right strut bearing. My guess is that it's a faulty part, or it was installed wrong. He wants to replace all 4 parts again... While I'm happy he's trying, at this point I'm skeptical that it will fix it. The car is going in tomorrow, so I'll post as soon as I get an update.
So, everything was finally fixed. While the top bearings and struts were replaced, in the end the noise was caused by the rubber dust shields on the struts rubbing against the rubber edge of the top bearing housing. MB greased it and all was quiet. No noise for a few days now. So moral of the story, it may be struts or the top bearings, or simply the sound dry / dirty rubber on rubber makes (silly design imo).
If not, here is a thread where you can see a few pics of how I re-greased the strut dust covers when adding lowering springs. You can also see the bearings that may go bad.
https://mbworld.org/forums/w218/6133...-e63-w212.html
No noise for a few weeks now...
Hopefully a dealer will take care of it for you.
I've only had one visit to service, but I'm getting the feeling I have an awesome dealer/service just from that one visit. I'm going to mention it when I go in to get my winter tires swapped to summers and my first oil change
I'm not fully convinced it's the dust shields rubbing yet...
I've noticed lately the sounds have changed a bit... It occurs more when the wheel is close to being fully turned to the left or right. It could however be the temperature changes outside.
I'm seriously thinking it's something rubbing where the steering wheel meets the firewall. Just because of how quiet the sound is, and I tried turning the steering wheel while parked and put my head down in the pedal area... I could be wrong, but I donno... I'm going to wait and see.
I just don't want to start having the vehicle taken apart if it's unnecessary when reporting the problem to service...
I might wait until winter is over and all this snow and crap is off the ground, give it 5-10 good cleanings (I always clean the wheel wells, etc)... and see if it gets better in warm temps...
It only occurs after the vehicle has been warmed up and driven. Turning on first thing in the AM it doesn't happen. And it doesn't happen at all when there's decent speed.
Sorry for another post...
Finally got some help finding where the sound was coming from. Got my dad to turn the wheel while I was outside of the vehicle...
Sound is definitely not coming from around the wheels/suspension. I'd bet money it's coming from the steering column/firewall area...
Received 2,070 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Had this same issue day one with two brand new 2014 e550's with distro
Dealer didn't work too hard before they said "normal"
I just don't want them to start replacing stuff if some good old KY lube and love is all it needs Especially since the vehicle is only 4 months old (but I've already put 13,000km on it haha).
Just got it back!
It was the dust shield... They were well aware of it. Removed everything, did something to it, and then put it all back... Sound was gone on the way home
My dealer rocks!
My dealer rocks!
Edit: Just check mine, the spring on the right does not seat against the stop-tab of the strut as you have mentioned on your thread. More reasons to believe these have caused the steering noise, especially on the right.
