DIY Lowering Springs CLS 63 W218 E63 W212
I just lowered my CLS last night and everything came out well except I’m not sure how to tighten the top 21mm strut bolt. I’m trying to do it on the car figuring Thanatos the pressure would allow me to tighten it but the strut shaft keeps spinning and so does the bolt. Did this happen to you?
Thanks.
https://mbworld.org/forums/e-class-w...ht-sensor.html
This is the part you are out of the car:
https://www.fcpeuro.com/products/mer...YaAspyEALw_wcB
Be careful popping it out. The arm that's attached to the height sensor is plastic. Try popping off the end on the metal bracket and then twist off the other end. WD40 is your friend.
Overall it's pretty straight forward, and takes about two hours per side (if you compress the springs by hand, this easily takes and hour per side).
Main tools:
- Spring compressor tool (I rented one from autozone)
- 21mm Deep Socket
- 10m socket
- 18mm open wrench
- T30 Torx wrench (I think, may be a T40)
- E18 Torx Socket
- E12 Torx Socket
- E10 Torx Socket
- Two socket wrenches and long extensions.
First loosen the main 21mm lock-nut on the tops of the strut. This nut keeps the top plate on and tension on the spring, so don't over loosen. A few full turns is fine. You can remove later, but it's hard to get the leverage when the strut is out.<br/>
Disconnect the ABS sensor and (on passenger side) brake sensor wires from their associated brackets. The sensors are attached with a 10mm and E10 bolts. Push the wires out of the way. Also disconnect the brake line fron the strut bracket. <br/>
Disconnect the stabilizer bar. It has a ball joint that spins freely. Use the 18mm wrench and the T30 (I think) wrench in unison to remove / re-install the nut. Push the bar out of the way. I re-used the nut with lock-tight when re-installing.<br/><br/>
The strut is attached to the wheel knuckle with two E18 bolts with 21 mm locknuts on them. I re-used the nuts with lock-tight when re-installing.<br/>
E18 Bolts
Use two socket wrenches with the 21mm deep socket and E18 socket. Extensions are needed. I needed a breaker bar to free the nuts.<br/><br/>
Bottom of the strut is free. Now remove the top 3 E12 bolts. The strut comes out very easily at that point. I held it from underneath while removing the last bolt from the top. <br/>
Strut removed...<br/>
Compress the springs... the bottom plate makes these type of spring compressors hard to use, but it worked. It scraped the edge of the plate a bit down through the paint (I filed them down and quickly painted them with rustoleum). When the spring is compressed like you see in the pic, fully remove the top 21mm nut. It should come off easily since you broke it free in step one. Always point the top of the plate away from any person or objects that you care about, just in case there is any tension left in the spring (there wasn't with the compression you see here). <br/><br/>
Slide everything off... here's the strut with the bearing, top plate, and dust shield removed.<br/>
Strut bearing (there's no upper control arm, the strut connects to the top of the knuckle and rotates when steering).<br/>
H&R spring (left) compared to stock spring.<br/>
Compress the new spring (a lot), and add grease to the top of the dust shield, and inside of the bearing. I had an annoying steering noise issue caused by these rubbing...<br/>
Grease the rubber contacts on the bearing...<br/>
Make sure the spring seats against the stop-tab. I hammered the compressor tool to twist the spring.<br/>
All together. Everything goes in the way it came out. I used lock-tight everywhere is was used originally (almost every bolt, but not the top 21mm bolt on the strut).<br/>
Quite the write up! I'll definitely be using this thread before the end of the year when I get my KW H.A.S springs.
rubbering -> rubbing
Last edited by dustinN; Dec 14, 2020 at 10:54 AM. Reason: edit: rubbering -> rubbing
