C218 CLS63, 2011 - 2019
DIY Lowering Springs CLS 63 W218 E63 W212
Old Jan 23, 2016 | 08:42 PM
moehler's Avatar
2014 CLS 63 S AMG / 2004 E55 AMG
Today I installed H&R lowering springs (PN 29076-9) on my 2014 CLS 63 S. Since there wasn't much installation notes out there, I figured I'd type them up. This should work for a W212 as well.
Overall it's pretty straight forward, and takes about two hours per side (if you compress the springs by hand, this easily takes and hour per side).
Main tools:
  1. Spring compressor tool (I rented one from autozone)
  2. 21mm Deep Socket
  3. 10m socket
  4. 18mm open wrench
  5. T30 Torx wrench (I think, may be a T40)
  6. E18 Torx Socket
  7. E12 Torx Socket
  8. E10 Torx Socket
  9. Two socket wrenches and long extensions.
First loosen the main 21mm lock-nut on the tops of the strut. This nut keeps the top plate on and tension on the spring, so don't over loosen. A few full turns is fine. You can remove later, but it's hard to get the leverage when the strut is out.<br/>
Disconnect the ABS sensor and (on passenger side) brake sensor wires from their associated brackets. The sensors are attached with a 10mm and E10 bolts. Push the wires out of the way. Also disconnect the brake line fron the strut bracket. <br/>
Disconnect the stabilizer bar. It has a ball joint that spins freely. Use the 18mm wrench and the T30 (I think) wrench in unison to remove / re-install the nut. Push the bar out of the way. I re-used the nut with lock-tight when re-installing.<br/><br/>
The strut is attached to the wheel knuckle with two E18 bolts with 21 mm locknuts on them. I re-used the nuts with lock-tight when re-installing.<br/>
E18 Bolts
Use two socket wrenches with the 21mm deep socket and E18 socket. Extensions are needed. I needed a breaker bar to free the nuts.<br/><br/>
Bottom of the strut is free. Now remove the top 3 E12 bolts. The strut comes out very easily at that point. I held it from underneath while removing the last bolt from the top. <br/>
Strut removed...<br/>
Compress the springs... the bottom plate makes these type of spring compressors hard to use, but it worked. It scraped the edge of the plate a bit down through the paint (I filed them down and quickly painted them with rustoleum). When the spring is compressed like you see in the pic, fully remove the top 21mm nut. It should come off easily since you broke it free in step one. Always point the top of the plate away from any person or objects that you care about, just in case there is any tension left in the spring (there wasn't with the compression you see here). <br/><br/>
Slide everything off... here's the strut with the bearing, top plate, and dust shield removed.<br/>
Strut bearing (there's no upper control arm, the strut connects to the top of the knuckle and rotates when steering).<br/>
H&R spring (left) compared to stock spring.<br/>
Compress the new spring (a lot), and add grease to the top of the dust shield, and inside of the bearing. I had an annoying steering noise issue caused by these rubbing...<br/>
Grease the rubber contacts on the bearing...<br/>
Make sure the spring seats against the stop-tab. I hammered the compressor tool to twist the spring.<br/>
All together. Everything goes in the way it came out. I used lock-tight everywhere is was used originally (almost every bolt, but not the top 21mm bolt on the strut).<br/>
Old Jan 23, 2016 | 10:49 PM
mcguirja's Avatar
Mercedes SL63 AMG; Mercedes E63 AMG S 4matic; Mercedes C43 AMG; Mercedes S Class, Mercedes GLK
Nice, looking forward to seeing your final pictures!
Old May 20, 2016 | 07:14 PM
val69's Avatar
Chevy Cavalier(206,000 miles)
Any pics?
Old May 20, 2016 | 07:49 PM
moehler's Avatar
This is the only pic I have right now...
Old May 20, 2016 | 08:28 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Nice, thanks!
Old May 30, 2016 | 11:46 PM
M66M's Avatar
CLS63 AMG P30
Looks great, what did you use on the rear end?
Old May 31, 2016 | 08:24 PM
moehler's Avatar
Thanks. I used adjustable lowering links from eBay for the rear. They were fairly easy to install and adjust (you can easily pop them on/off with the car jacked and the wheels on). It took 4-5 tries to get it right.
Old May 31, 2016 | 09:09 PM
chiromikey's Avatar
How is the ride quality and how close were you able to get the alignment? These cars eat up the inside tread bad enough at stock height!
Old May 31, 2016 | 10:05 PM
moehler's Avatar
Overall it's similar to stock. It's stiffer, but I found the stock suspension quite stiff, so this doesn't feel much different. It's comfortable / livable but firmer. The alignment is spot on. Much better than my lowered E55.
Old May 31, 2016 | 10:34 PM
chiromikey's Avatar
I could never get my E55 to quit eating tires and I tried every adjustable arm and bushings available. I've been putting off lowering my W212 for this reason. Btw, my E55's alignment was supposedly within spec too!
Old Jun 2, 2016 | 12:26 PM
Yasser Haider's Avatar
2014 Mercedes CLS63 AMG
I am facing an issue with my fronts rubbing against the fender liner and i havent even lowered it yet..
I have vossen 20" wheels 245/35/20 in the fronts.. i might be wrong but will check again... and 295/30/20 on the rear.. Pilot Super Sports
any solution to this?
Old Jun 11, 2016 | 08:48 PM
moehler's Avatar
Here's a few more pictures to show the ride height.
Old Jul 28, 2016 | 12:23 AM
rolling18's Avatar
2012 CLS63s White
would you be interested in selling your stock bits?
Old Jul 29, 2016 | 12:36 AM
moehler's Avatar
Not at this time. Thanks for asking.
Old Aug 27, 2016 | 01:53 AM
6speeddave's Avatar
MB
I see a front axle, 4-Matic? Wondering if all hardware and setup is the same on a earlier RWD W212 E63. I am looking to put my H&R springs in my 10 E63 this weekend.
Old Aug 27, 2016 | 08:08 AM
moehler's Avatar
That's a good question, I'm not sure how the awd and non-awd suspension geometry differ. It would be good if you can post any differences that you find.
Old Aug 27, 2016 | 10:25 AM
6speeddave's Avatar
MB
Definitely will do, hopefully will have lift access next weekend to do so.
Old Jan 19, 2017 | 12:41 AM
JDMAP1's Avatar
W222 S550, W218 CLS63, W166 ML550, Titan, Sentra
Just picked up a 2012 PCE and absolutely love the car. I also lowered it via Evoklass coilover.
It is slight different from RWD vs AWD. Everything is the same except the struts are mounted to the back of he calipers and one big *** bolt holding the upper calipers to the struts. Ride quality is exactly the same but now with adjustability.
Old Jan 21, 2017 | 12:16 PM
emericr's Avatar
2021 Porsche TTS
Nicely done. Car looks great.
I did the same on my 2012 CLS and had no issues. I also had 20 inch wheels all arounf.
My KW springs are collecting dust in garage so if someone wants to make me an offer, pm me.
I also have a convenience box for sale.
Old Jan 26, 2017 | 03:56 PM
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
Moehler, please tell what kind of grease do you use?
Old Jan 27, 2017 | 01:45 PM
moehler's Avatar
I used a plastic safe white lithium grease. But, it's probably safer to use any silicon based grease.
Old Jan 27, 2017 | 01:52 PM
moehler's Avatar
Here's how the car sits now...
Old Jan 27, 2017 | 01:56 PM
moehler's Avatar
A few more of Here's how the car looks now. The springs have held up perfectly.
Old Jan 28, 2017 | 05:24 PM
Cyclone1's Avatar
CLS55 AMG
The car looks great. What wheels are they?
Old Jan 28, 2017 | 06:25 PM
moehler's Avatar
Thanks! They are Vossen VFS 5.
