C218 CLS63, 2011 - 2019
Sensor short circuit
Old Mar 23, 2019 | 08:08 AM
TrueBlue's Avatar
CLS W218
Hi,
I'm getting an engine management light P0546. Two different diagnostic tools gave the same fault code.
1. Exhaust Gas Temperature Sensor Circuit High Code Bank 1 Sensor 1
2. Temperature sensor 1 exhaust system (cylinder bank 1) has a short circuit to positive. There is a short circuit to positive or an open circuit.
I had the sensor replaced. But, the same fault code is showing again after being cleared.
CLS 250 CDI Blue Efficiency 4DR AU
Engine no. 65192430599572
Before I start stripping down to troubleshoot the wire, can anybody tell me where the wire from the sensor goes to?
Old Sep 16, 2021 | 10:40 PM
LauraS's Avatar
1990 Mercedes 190E
If I recall I used that connector to heck the signal to the coil with an old dwell meter. I will check it to be sure it is tight. On the issue of maintenance costs to be truthful I rarely had anythng to do with this car while my husband was alive. He looked after all the care of vehicles and other equipmenand I don't know what he might have replaced. I am really new at this crar maintenance and it has been a steep learning curve but thanks to you it has been easier than I ever imagined.
