C218 CLS63, 2011 - 2019
Spark Plug Replacement
Old Nov 13, 2019 | 10:40 AM
ecomking's Avatar
2014 Mercedes cls 63 amg
Do I need any special tools to change spark plugs on 14 CLS63amg?
What spark plugs should I replace with?
Old Nov 13, 2019 | 11:18 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Special socket, OEM plugs only, must be torqued exactly to spec or can melt engine down
Old Nov 13, 2019 | 11:42 AM
ecomking's Avatar
Do you have link to the socket and know the torque specs by chance?
Old Nov 13, 2019 | 01:16 PM
ecomking's Avatar
nevermind, I have the torque wrench for 23nm and thin wall 14mm 12pt socket
Old Nov 24, 2019 | 11:44 AM
Maduro's Avatar
2012 CLS550 AMG Pkg
Do you mind posting links or part numbers? I'm thinking of doing mine on a 2012 CLS 550 (61 000KM) to try and remedy a very intermittent rough idle that shows up. Did you end up buying that special sleeve to remove the coils?
Old Nov 29, 2019 | 01:50 AM
mixmaster's Avatar
2014 MB CLS63 S-Model
You will need a 14mm 12 point socket to finish the job. I use one manufactured by ATLIN. You can get it from Amazon. I believe you will need an E-TORX bit for that. If you don't have a TORX bit set or an E-TORX bit set, you should really get one.
Amazon Amazon
It says its for BMW but this is what I use.
Old Nov 29, 2019 | 02:20 AM
Maduro's Avatar
2012 CLS550 AMG Pkg
https://www.amazon.com/ATLIN-Socket-.../dp/B01MXJ3X7P
Thanks for the reply, yes I have a good TORX + E-TORX set.
As for the ATLIN socket it would be instead of this tool here for the plugs themselves? --> (https://mbworld.org/forums/attachmen...o-photo619.jpg)
Btw, as for the rough idle, I found another thread regarding faulty cam sensors on W218's around 2011-2013 so I decided to check mine and sure enough I had the bad ones as well. Just replaced them today with the redesigned part and it has solved my idle/CEL P2096 messages. Regardless I'd still like to do the spark plugs and coils soon.
Old Nov 29, 2019 | 10:40 AM
mixmaster's Avatar
W278589000900 would definitely be the Mercedes Benz tool of choice for changing a spark plug. I didn't want to fork out close to $100 for a spark plug socket regardless if it is somewhat customized. Glad you got the idle problems fixed!
Old Nov 29, 2019 | 12:29 PM
Maduro's Avatar
2012 CLS550 AMG Pkg
double post
Old Nov 29, 2019 | 12:30 PM
Maduro's Avatar
2012 CLS550 AMG Pkg
Ya I'm with you and would rather avoid the official tool as well. Just want to confirm the link you sent is indeed accurate as Amazon tells me it does not fit my 2012 CLS 550
Old Nov 29, 2019 | 01:02 PM
mixmaster's Avatar
The Amazon seller just needs to their list of cars this tool is compatible with. When I ordered the tool it said the same thing. I went and measured the recess leading to the spark plug and since the tool has a outer diameter of .7" (17.78mm) and the recess has is a bit larger (~22mm) I choose to buy the tool. You have an M278 engine which has the same spark plug recess measurements than my engine.
Old Dec 2, 2019 | 09:35 PM
Maduro's Avatar
2012 CLS550 AMG Pkg
What are your thoughts on doing coils, is it necessary for 42 000 miles?
fyi, after doing my camshaft sensors (known to be faulty for those years) my check engine light hasn't returned and the car performs normally again
Old Dec 2, 2019 | 10:30 PM
mixmaster's Avatar
Maduro,
It is wise to go ahead and replace them since you would be taking your spark plugs out anyway. You should be good for another 50-80K. If you do decide to change the coils out, save the old ones just for backup, although you will be yanking on them to remove them you never know when you need a coil or two.
