Question about Resonator Delete and New Mufflers
Hi all. I have read many threads saying deleting the resonator to get more sound is a great mod without getting much or any drone. Have any of you deleted the resonator and put on new mufflers such as the Renntech sport mufflers together? I was thinking of getting the FI valtronic exhaust but that is fairly $$$. A resonator delete is very cheap and although the Renntech mufflers are pricey, still over 1K less then the FI cat-back exhaust. By the way, anyone ever use any other mufflers other then the Renntech Sport Mufflers? I am sure magnaflows or other brands are way cheaper but I do not want to loose the AMG sound either. Thanks in advance for any help with this matter.
Regards,
LF
Regards,
LF
I personally wouldn't chop off my AMG exhaust. I removed my secondary cats and resonator and the car sounds LIKE a BEAST. Downshifting makes an incredible bark with zero drone, I couldn't be happier. Only downside is my neighbors probably don't like my 6am cold starts.
Armani
Armani
Regards,
LF
Regards,
LF
CLS550 AMG Pkg.
Armani
Armani
do you have a pic of what was removed?
i replaced my resonator with straight pipes and added valve controlled cut outs right before the mufflers; sounds really good
Regards,
LF
Regards,
LF
These cars brand new were north of $100k and the valve control exhaust system from Carlsson retailed for almost $7k and the Brabus system was basically $10k, Akrapovic was also $10k+, and these systems were engineered and designed to retain and increase performance for these CLS63 cars, and keeping them functional. Going in and cutting off resonators and deleting mufflers for sound may provide some sound improvement, but seems like hacking up a once $100k car does not seem like a safe remedy for proper function. If you honestly cannot afford a Valve Control exhaust system, I would honestly say to leave the car stock and don't do anything to cheapen or risk the performance. Just my 02.
Hi and thanks for the reply! Where did you get the valve controlled cut outs? Did not know that was an option? So I could keep the stock exhaust and get a valve controlled cut out to keep valves open to increase sound? Tell me more please!
Also you are correct, there are no secondary catalytic converters on a W218 CLS63 that I know of...at least 2015-2017.
Regards,
LF
Regards,
LF
[QUOTE=M1RAG3;8013655]im pretty sure there are no secondary cats on the w218 CLS63, only primary cats in the downpipes
[/QUOTE
Regards,
LF
[/QUOTE
Regards,
LF
Hey Larry, I still have the Carlsson Valve Control exhaust system available, this system is still the absolute best value available in the market and is TUV tested and approved. If you want that extra sound and bark, the open position provides just that, and if you want a more subtle tone the option to push a button and close them is there and you retain all the correct flow and performance, no cabin droning and no exhaust smell inside.
Believe me I thought hard about buying your exhaust but for the money, deleting the resonator to get sound appears to be a no brainer. The resonator can be cut out and then replaced if need be very cheap and it does not hack up the car. Same with the mufflers IMO. This is all easy to do and can be reversed without harm. Only downside is that I can't control the sound like would be able to with your exhaust. I have two worries with your exhaust, the first is I do not know how it will sound? I do not know anyone with it and I just can't tell from a video? If it sounded like the FI valvetronic exhaust then that would be great! The next worry is fitment with my aftermarket rear diffuser and the muffler tips...and how it will connect to the car...just too many unknowns for me unfortunately. How much are you selling it for again? The resonator on it looks like a small secondary muffler...is it restrictive at all? It is such a rare exhaust...
LF
not the least bit of drone. It’s barely noticeable over stock in normal driving. Maybe a bit deeper and slightly louder. The biggest difference is during cold start and WOT. And it always brings a smile to your face.
The following 2 users liked this post by 1MavRick:
C63fora2w1 (03-29-2020),
france2112 (03-28-2020)
Hi, hope you are well.
2010 Mercedes-Benz CLS 550
Here's the YouTube clips.
https://www.youtube.com/results?sear...+Cutout+System
