In need of a little help and understanding of my K4 Dyno
2006 CLS55 K4
I still can't get enough power out of my car. I'll try to keep this short since it has been going on for 4 month and a lot has taken place.
It has been in a long process of trying to get my car up to power since I had a Kleemann K4 package installed in Feb. All of the components were installed with ~100 miles on the car and the break in was completed per Kleemann's instructions. I first had the car dynoed 2-9-06 and I made some very low numbers for a K4 vehicle look here to see:First K4 Results
I have had Brandon from Kleemann out here to go over the vehicle and try to resolve this issue. We came up with an answer on what we think we should do to the car to figure out if it is a mechanical issue or a computer issue. We had a new larger pulley custom made to try and get more HP. This is where I am right now with the car. I have the pulley installed and just got back from the dyno. The car is making more mid-range power but it drops back down on the top end. I still can't even crack the 460hp # anytime I have made a pull in 4th gear. In my old post I made 464hp, but that was in 3rd.
Right now it seems as though nobody really knows what to do to make any more power. We don't know if it is a mechanical or computer related problem, but we do know that the car is just making really low numbers. Since the first time I have had the car dynoed I have been to two different shops, and have had many different computer changes along with a new water pump installed, but nothing seems to make a difference. This was the first time in over 25 dyno pulls that the graph has even looked any different, yet it still peaks out at about the same number.
I'm just hoping that one of you guys who has a little more experience looking at dyno sheets or knowledge of the car can help me out on this. I feel like I paid for the K4 performance and I'm barley getting the power of a K2 package. Right now I am making 455rwhp and 542lbtq. The torque is up a little from my normal of about 520, but it still seems low, and I know that the HP is still really low.
![](http://i3.photobucket.com/albums/y70/Stiff1/scan0001.jpg)
2006 CLS55 K4
They claim 640hp and 640tq at the flywheel. I know that my tq is decent just not compared to what others have put down. My hp should be between 515-520rwhp. Since I'm only getting mid 450s every single time, I know that I am off at least 65-70rwhp if not more. I'm just trying to figure out why I can't get any higher HP numbers then this.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
SL55 AMG, 2006 Range Rover Sport with Kahn Design Package
This is just a suggestion; maybe you can send the car down to Miami (RT headquarters) so they can take a look at it and try to improve your numbers.
Stiff, all i have to say is amazing car. hang in there buddy! and please keep us posted on the progress.
just curious; if kleeman cant figure out the problem and cant get the car up to spec, are they going to refund your funds?
What's the sequence of events for the three dyno pulls above? The blue curve is distinctly different than the other two. Were they all done at the same time and dyno setup?
If I understand your post correctly, you have the standard K4 package with the addition of a larger crank pulley - IOW, more boost. Is this right?
Looking at the two similar curves, I see three problems:
1) the A/F mixture is too lean between 2500 and 4500 RPM. This should be between 12:1 and 13:1 in that range.
2) the upper RPM torque is falling off faster than it should be.
3) the torque curves are not as smooth as they should be.
#1 could just be a problem with the programming in the ECU. Did Kleemann tweak it after the first series of pulls? It could also be a problem with your fuel pressure. That's fairly easy to check.
#2 and #3 could be caused by tire slippage or S/C belt slippage. Tire slippage can be fixed with a 2x4 upside the head of the dyno operator. Since you have a non-standard pulley size, check for proper tension of the S/C belt.
One other thought - since the TB was replaced, have Kleemann check the functionality of the by-pass valve under the TB. It could be improperly set and bleeding off boost.
Have you had any diagnostics performed to check for codes? How about data logging during a dyno pull? We'll need more info to properly diagnose this (e.g, timing, IAT, manifold pressure, etc).
2006 CLS55 K4
The blue curve was done at the end of March with Brandon from Kleemann watching. The other two were done after the new pulley was installed.
Yes this is correct. I have a larger crank pulley and a smaller water pump pulley.
I agree. There has not been any change to the computer since the new crank pulley, so I can only assume that this would be the reason.
I was told that because of the larger pulley and making more boost, the kompressor basically can't keep up in those higher RPMs, so you will always gain more mid-range, but loose top end.
I have no idea what would cause that.
I do not believe that I have a problem with the fuel pressure. Kleemann has "tweaked" my program after the 1st, 2nd, 3rd, 4th, 5th, and 6th series of pulls, but I have not yet been able to hit the numbers that I should be at.
After 25+ dyno pulls I have yet to see any slippage of the tires. I am also on my third belt even though the first two don't seem to have any problems. We even had the clutch on the Kompressor checked just to make sure that it was not slipping.
This was my initial thoughts also, but I was told that the by-pass valve is either open or it's closed there is no in between or any way for it to get stuck in any other postion.
...............Did you do a pre-mod dyno? If so, what were your baselines like?
..............secondly, I know this has probably been checked, but look at your intercooler water pump.
.............lastly, I know it is a pain in the neck but seems you get the best results if you do the different upgrades in stages with pre and post dyno and tunning each time. You have spent so much time on this, you may wish to go component by component starting with pulley then dyno, then pulley plus ECu then dyno, then pulley ECU headers then dyno, then pulley ECU headers plus ECu after headers then dyno, then throtle body then dyno and perharps throtle body plus ECu then dyno. This is what I did on my G55 K4 and got 490 HP in 4th gear dyno which translates to 650HP in a 4wheel drive car.
...........Good luck
Ted
Ted
2006 CLS55 K4
I do not have a pre mod dyno and I never did it in stages. The car was bought and within 1-1/2 weeks it was packed full of kleemann goodies. Everything was put on the car before I ever even had 100 on it.
I was told that the intercooler water pump was not working so it was replaced and redynoed. I ended up with the exact same numbers as I has before. I think that the car has a load limiter set in the ECU and it seems like nobody can find out where it is to get rid of it.
Originally Posted by From previous post:
1) the A/F mixture is too lean between 2500 and 4500 RPM. This should be between 12:1 and 13:1 in that RPM range.
Yes, this sounds plausible.
I don't buy their explanation. The Lysholm is a positive displacement S/C. If it is sized correctly for an engine, it can keep up throughout the RPM range. Plus, with a larger crank pulley, it's spinning faster wrt the engine. IOW, it's putting out more air at all RPMs. The torque is falling off for another reason.
Were they replaced for wear, or for size issues with the larger pulleys?
I'm not so sure about this. I believe there is an 8-wire connector used on that valve. That would imply a stepper motor is used to control it. Why add that much complexity if it'a an open/close valve?
Originally Posted by Stiff1
I did hook up a boost guage and the car is making just about 1 bar, so I am just over 14 #'s of boost right now.
Your first post-mods dynos look pretty good - except for the upper-RPM A/F ratios. See how the HP curves flatten after 5000 RPM, where the ratios dip to 10:1? Notice that the red HP curve is about 20 HP higher than the other two? This correlates with the red A/F ratio being a little higher than the others in that range. If you decide to keep the 2nd larger pulley, have Kleemann match these curves with less fuel after 5000 RPM. Also notice that these curves are corrected to SAE values. That means that they are about 3-4% less than what Kleemann would measure - the torque would be about 550 instead of 530 and HP would be about 475 instead of 460.
The 2nd pulley should have added another 25-30 HP to those numbers. Out of curiousity, why did Kleemann change the pulley? The boost level of the 1st larger pulley was OK. Were they trying to get the HP level up to their advertised values instead of figuring out what's wrong?
Since you don't have a baseline dyno, it's hard to determine if the mods are performing properly. They may be close, but your car is in the lower part of the normal power distribution.
If the car were mine, I would go back to the 1st larger pulley, tweak the A/F ratio so it doesn't dip below 11:1, upgrade to the Johnson pump, and drive it aggressively for a few days. Then I would take it to the track and establish a trap-speed baseline. This number needs to be greater than 120 mph. If it isn't, then Kleemann needs to get involved again. I would also implement data logging to see what the timing is doing at WOT.
2006 CLS55 K4
Thanks for the info Grumpy. Kleemann decided to change to the larger pulley only to determine if the car was hitting a load limiter around 460rwhp and not allowing it to make any more power. This seems to make since because out of my 25+ pulls I have had the A/F at 10:1 and I've had it at about 11.5:1 with NO change in my HP numbers. No matter what we have done, including 7-10 different ECU tunes put in the car, it will not go over 459.xxrwhp on the dyno in 4th gear. Even after the pulley swap, I expected to see a higher peak number, but instead it fell right where it alway does just below 460. I know I need to take it to the track just to have some numbers, but I don't know what a K4 car should be running. Kleemann told me 12.0-12.2@120mph would be good, but I feel like I should be in the 11s without too much of a problem. What do you guys think I should run?
MB 2006 CLS55 K4/LSD, 2006 VY C6Z06, 2005 X5 4.4
Hello,
I have a cls55 K4 car, and I did 11.9 on the track and by best trap is 121.4 trap speed on my first time out. The guys on track said with more experience and track time I should be mid 11's. Kleemann Dynoed my car at 600 at the crank, the said afters few hundred miles of running it hard it should settle at about 620. I am having the car dynoed this week to get rwhp. I will let you know my results. Thanks
MG
MG
BENZO
my personal thought
yeah 10.1 AF ratio is way too low. For safety and power 11.1-11.5 where Grumpy said.
Just so I know and other know what does the K4 get the Boost to? I thought it was over 15lbs? If so then that really is your problem. Your not make enough boost to attain the power level that the K4 says
..........I think your car may not be quite as off the mark as you think. In order to get customers, a lot of tuners kinda inflated their HP numbers a bit, Kleemann included. According to Kleemann, a K4 should be making upwards of 500rwhp. That is a bit off an exergeration in my mind. There maybe one or two such cars. Now that customers have come to expect these numbers, the tuners don't know what to say. I think lack of a baseline dyno is the main problem. Stock AMGV8K's have dynoed anywhere from 389 to 420. So if your car is in low range, you may actually be fine. If it were me, I'll take everything out, reflash the ECU to stock and dyno the car stock and go from there.........but I'm a bit crazy, but then you have spent almost as much time tinkering with everything.
........MG0427 says his car dynoed at 600crank HP, your car with 464rwhp is making 575HP at the crank, not much different from 600. The idea that the car with 600crank HP is going to pick up another 25HP is a way for the tuner to settle your mind that you will one day reach the promised land.
...........more importantly, your car is making an amazing 533rwtorque.....that is 670lbft of torque at the crank. To many, 575HP and 670lbft of torque will be significantly faster than one with the promised 600HP but less torque. So, a bit of perspective is needed. Take your car to the track and see what you car can do.
Ted
I was told that the inter-cooler water pump was not working so it was replaced and redynoed. I ended up with the exact same numbers as I has before. I think that the car has a load limiter set in the ECU and it seems like nobody can find out where it is to get rid of it.
Guys can you help me understand something here, I just don't understand why you would want to modify a engine that is damn near its full potential from the factory. If 469 hp isn't enough why buy the car?
I would guess your spending $5-10K to increase power for a few extra HP, not to mention all the time wasted and potential to have MBZ void your warranty on the engine. Don't take this the wrong way but what is the ultimate goal with this car? Street racer?
.............it is just one of those things you will not understand unless you are part of it. Modifying a car and getting it faster is much more satisfying than buying a car that is as fast as your modified car. I don't gamble. Have never understood the allure, but an entire US city was built arround the concept of gambling. Las Vegas today is the fastest growing city in the US.....and they don't miss me.
Ted
Ted
Ted
Sorry for hijacking this thread, I'll shut up now
thanks for clearing that up grumpy. Grumpy, then what would you say is the power increase per 1 PSI of boost? 10-12rwhp?
But a V8 supercharged MBZ that puts out 469 HP? I think that is pretty close to being maxed out on HP, and in realitly even if you do get 15-30 more HP, you really can't feel that, it comes down to the driver and how he can launch the car if your going for 1/4 mile runs.
Hi Ted, I somewhat understand the modifying part, every car I have owned I've modfied the appearance, which some say would be a waste a money, but it's for personal taste and appearance. I am all for making a car go faster as i'm constantly trying to figure out how to make my race car go faster. But a V8 supercharged MBZ that puts out 469 HP? I think that is pretty close to being maxed out on HP, and in realitly even if you do get 15-30 more HP, you really can't feel that, it comes down to the driver and how he can launch the car if your going for 1/4 mile runs. I think these tuners mislead some people on what there mods can do, its unfortunate because it seems to take away from the enjoyment of the car since it spends a lot of time in the shop.
Sorry for hijacking this thread, I'll shut up now![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Ted
