Air pressure for stock CLS 55/63 tires
Old Sep 26, 2007 | 12:50 AM
drews1's Avatar
Hi guys, could someone please provide me with the factory recommended air pressures for the stock CLS 55/63 tire and wheel setup.
Thanks so much
Old Sep 26, 2007 | 01:01 AM
MLMCLK430's Avatar
2006 CLS55 AMG
Thanks so much
Look in the door pillar on the driver's side and the air pressures are on a sticker. I believe it is 41psi for the front, 38psi for the rear.
Old Sep 26, 2007 | 01:19 AM
drews1's Avatar
Unfortunately I don't have the car just the wheels and tires I'm putting them on my CLS 550 and just wanted to know the proper inflation #'s. Is this a definitive answer? Is the rear pressure lower than the fronts?
Old Sep 26, 2007 | 12:09 PM
Centurion's Avatar
a car that gets very poor gas mileage.
You can also check behind the fuel cap door for recommended air pressures at different loads.
Old Sep 26, 2007 | 02:54 PM
drews1's Avatar
I appreciate your input, but once again I don't own the car, just the wheels and tires.
Was hoping someone could please help me out w/ this.
Old Sep 28, 2007 | 12:33 AM
drews1's Avatar
Someone, anyone, pleeaaasseeee!!!
Old Sep 29, 2007 | 12:36 PM
VTen555's Avatar
2016 SL550 Mille Miglia 417
I would use your cars recommended tire pressure readings
Old Sep 29, 2007 | 06:04 PM
Jocampo's Avatar
06 CLS55 AMG
In the center pillar of my cls55 it says 38 in the 2 front tires and 41 in the 2 rear tires.
Old Sep 29, 2007 | 08:44 PM
drews1's Avatar
Thank you very much, much appreciated
Old Sep 30, 2007 | 08:11 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Check again. One setup is for over 100 mph and the other is for under 100 mph. Maybe mine is different due to my 030 performance package with the 186 mph limiter.
Old Sep 30, 2007 | 08:26 PM
Jocampo's Avatar
06 CLS55 AMG
Camera phones suck. damn blurry as hell. here's the center pillar sticker. and some photos from an AMG Renntech meet here in NY over the weekend. The SLR was insane!
Attached Thumbnails Air pressure for stock CLS 55/63 tires-image_028.jpg   Air pressure for stock CLS 55/63 tires-image_029.jpg   Air pressure for stock CLS 55/63 tires-image_030.jpg
