Tires-->2fronts 2 rears
OO7 CLS63///G55TANK ///S80-T6///R1///R6
I need to replace the rear tires. Is it bad for the ride if I put 2 conti's on the rear to go along with the existing nittos in the front? My front nitto's are still new.
E63 P30, CL500 Sport
Although definately do-able, it is not generally a good idea having two different sets of tires with different tread patterns. You may experience certain vibrations and slip after the tires wear to a certain level
perfectly fine as long as one set is not worn out. I have totally different tires on my car fronts Bridgestone RE05A rear michelin pilot sport cups. ride is fine.
The rear tires are what wears out so keep the fronts and just replace rears until you need 4
02 996 Turbo, 05 CLK55 AMG
E55 AMG + Mustang GT
I've had Pirelli Pzero Rosso on the front and BFG KDW2 on the rear in my 350z, and didn't have any problems at all.
Big and Heavy 03 CL
No worries. I have Pirelli Pzero's up front and Yoko asv100's in back. The main issue is equal tread depth and tire compound. Mine are both summer tires of equal tread depth, and compound. You might notice a difference in standing water or driving out of a pothole, etc.
Thanx fellas. I thought I was gonna get ridiculed for doing this but it turns out alot of you do it already.
Im done with nittos, They wear out too damn fast.
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
Well I Headr that the PS2's are the best out right now! Is that true I want to replace my rears for better traction.
