Wheels & offset
Old Sep 18, 2008 | 11:24 AM
azncarjunkie's Avatar
CLS55 black opal
Wheels & offset
Was looking for Monoblock VI's but it seems there aren't that many used ones out there (yup, trying to be somewhat economical and save a few bucks if it's easy enough).
Brabus CLS wheels have an offset of about 20-something. But lots of the S/E-class wheels offset are around 40-something. Is it possible to just take the e-class wheels and use spacers?
Is there any sort of negative impact to doing it that way vs just getting wheels that are made with the proper offset? I'd imagine the 'face' of the wheel might be further out or deep, but other than appearance?
Old Sep 18, 2008 | 05:55 PM
newguycls55's Avatar
whats your budget? I know a few people looking to sell their wheels for cls.
also what type of wheels and desing you looking for?
Old Sep 18, 2008 | 09:12 PM
CLS55 black opal
Preferring Brabus monoblock VI in 20's. Might be ok with 19's if it's a really good deal. Looks like we're local too.
Old Sep 18, 2008 | 09:40 PM
MLMCLK430's Avatar
2006 CLS55 AMG
I don't believe that there is a negative impact with using spacers to push the higher offset wheels out from the E-class to the CLS as long as you are using the longer, necessary bolts.
The CLS usually requires a much lower offset, like around 22mm for the front on a 9 inch rim width. That was what I had on a set of 20's before and around 28 on an 11 inch rim wide in the rear.
Since you have a CLS you might as well take advantage of the use of lower offsets to have deep lip wheels, which is one of the reasons why I bought the CLS.
