Did self oil-change today on my CLS 55
I made a good decision.....both drain plugs were on so tight that I needed a breaker bar to take them off. Both of them were leaking, which you can't really see because of the shields underneath the car. I looked at all of my receipts from the previous services and the plugs and washers were never replaced, hence the leaking. They also overtighted the oil filter. I don't know where some of these mechanics think that fasteners need to be tightened with as much force as they can muster.
I let the oil drain out, after driving the car around for 20 mins to get it hot, until there was barely a drop coming out, then installed the brand new drain plugs & washers, poured in 9 quarts of Mobil 1 5W-40 ESP Protection Formula from the Mercedes dealer, replaced all the rubber O-rings on the oil filter holder & fleece oil filter, let it run, checked the level on the dash (I didn't buy the dipstick yet), cleared the service code, good to go.
I changed the cabin filter also per the dealer's service also, which took all of about 45 seconds to complete. Overall, fairly simple and straight-forward like any other oil change with the exception of taking off the covers underneath, held with (8) 8-mm screws, which really wasn't that big of a deal.
I justed wanted to let everyone know that doing some of your own maintenance or repairs does not necessarily mean that someone is being cheap, but that it is more of a 'vested interest' thing. I am including below a list of all the items that I used to do my recent service if anyone was planning to do it themselves:
Fleece oil filter: Part # 000-180-26-09 $27.60
Drain plugs: Part # 000-990-53-17 $5.30 each (2 needed)
Copper washers: Part # 007603-014106 $1.85 each (2 needed)
Mobil 1 5w-40 ESP: $6.95 each (9 needed)
Cabin filter: Part # 211-830-00-18 $40.50
Type B Oil filter wrench (Auto Zone): $3.99
Happy motoring to all
C43AMG: That is why they call them stealerships. I probably could have found it cheaper online, but I wanted it right away. The one on my Camry cost $30, so figure for a Mercedes $10 bucks more was not that out of line.
Something useful for the DIY
http://www.mercedestechstore.com/pdf...2008-16-02.pdf
Good info.
Where does one get an oil dipstick and dipstick tube for an 06' CLS55? Stealership? Anyone have part #'s?
Can anyone explain the discrepency between the 7.5 quarts in dyno mode and the 9+ quart capacity it takes to feed these beasts?
Anyway..is there a reset need for when the oil is changed? excuse the noob question, but I am a DIY guy and love any input I can get.
They go though about 10 cars like yours per day and don't give a **** about it.
And in the 63 engine the oil cooler in front of the engine is lower the the pan so you need to remove the drain plug from it . But becarefull its aluminum so it can strip easy .. but same as the 55 you cant use a extractor because it will leave about a quart in the cooler... Im glad that you are doing your own servicing . I have been a tech at a dealer for over 15 years and always wonder why people dont do simpler maintnaince them self .. Some people can handle this and some perfer to bring it to the dealer
