LED license plate lights
Old Dec 13, 2008 | 01:08 PM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
What's up guys.
I love seeing the bright white glow on the license plate of Newer Lexus models.
I tried to install LED bulbs once, but I got a few codes from the car in return.
Is there a bulb on the market that will work ?
Old Dec 13, 2008 | 02:55 PM
jagata's Avatar
S6 LP640 E500
Don't throw away those leds, just add a resistor to the power line of the bulbs. Go to Radio Shack and get a 2pack of 10 watt 50 ohm resistors part# 271-133. Hope that helps Good luck.
Old Dec 13, 2008 | 07:28 PM
NJBoy115's Avatar
2006 CLS55 AMG President Edition
Originally Posted by khelawanb
What's up guys.
I really like those LED lights on the Lexus license plates too!
Let me know if you get them to work...I would like to install them in my car too.
Old Dec 13, 2008 | 08:39 PM
cls63kid's Avatar
what size led bulb do we need for the license plate? Thanks
Old Dec 14, 2008 | 05:44 PM
mikep17's Avatar
cls63
all i did was bought the same bulbs pretty much.. 34mm i believe. they are the same bulbs with a blue lense so it gives off a very white light.. it looks much better then yellow b4
Old Dec 14, 2008 | 07:22 PM
wusty's Avatar
Looking...
LED's
Check out this thread. I just ordered some 2 days ago so we'll see how they work when I get them.
https://mbworld.org/forums/clk-class...ed-lights.html
Old Dec 14, 2008 | 10:08 PM
khelawanb's Avatar
Nice! Keep us posted man. I cant wait, lol. If it works I will buy some for sure.
Old Dec 16, 2008 | 03:48 PM
wusty's Avatar
Looking...
I installed my LED's from autolumination.com and they are not error free. They were flickering and will need a resistor installed. The size was good though,39mm for my 03' E320. I need to find a good link of how to install a resistor now. I don't know how to.
Old Dec 16, 2008 | 04:01 PM
e3202nv's Avatar
08' cls550 08 bmw m6 conv
this guy sells the same ones on ebay error free
http://cgi.ebay.com/ebaymotors/SMD-H...Q5fAccessories
Old Dec 17, 2008 | 12:22 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
A few guys i know useed these with no resistors..The BMW bulbs are the same size as the E/CLS bulbs..
http://www.ecstuning.com/stage/edpd/...bcategory=ZIZA
Old Dec 17, 2008 | 12:39 PM
ohlord's Avatar
Look
in the W210 forum.LED festoon lights and gives the diy to install the resistor so you don't trigger the lamp malfunction warning.
Old Dec 19, 2008 | 01:46 PM
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
I did this over the summer. Yes you will need the resistor foe most LED lights they just do not pull enough current so it will flash. Real easy to install but the resistor gets hot so make sure you put it somewhere on the wire where it won't touch trunk cloth!!
Old Dec 19, 2008 | 03:20 PM
blackcls63's Avatar
07 CLS63 | 06 SLK350
which ones did you end up getting? i have the resistors , but haven't bought the LED's yet...
Old Dec 19, 2008 | 11:44 PM
wusty's Avatar
Looking...
Do you have any good tips on how to install the resistor? Where did you get your resistors from? Do I need one for each bulb?
Old Dec 20, 2008 | 12:43 AM
e3202nv's Avatar
i got the ones off ebay and its perfect no problems and no error message light colors is very nice to i will post pictures up tomm here is the link i got the item from ebay http://cgi.ebay.com/ebaymotors/SMD-H...Q5fAccessories
Old Dec 20, 2008 | 03:18 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
nice .. ready cooled,
this is important because resistors that are applied to avoid cel, will raise temp
Old Dec 20, 2008 | 10:22 AM
wusty's Avatar
Looking...
Your lights were just plug and play and worked fine? On your E or CLS?
Old Dec 20, 2008 | 10:45 AM
wusty's Avatar
Looking...
I don't get it because the stock bulbs are pulling 5w. But those Ebay LED bulbs are only pulling 3w. How can that work? What happens to the lost 2w? And why wouldn't the computer trigger errors for the lost 2w?
Old Dec 22, 2008 | 05:43 PM
wusty's Avatar
Looking...
Screw it
I'm not splicing wires and adding resitors. I'll just buy these http://www.hoen-usa.com/licenseplate2.htm
Attached is how the Hoen lights look compared to the stock. Good enough for me until LED's can come with built in resistors that are truly plug & play.
Old Dec 23, 2008 | 12:31 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
Please put up pics!!!
Old Dec 23, 2008 | 11:29 AM
e3202nv's Avatar
yea just pluged it in and no problems with error lights it has a builtin rest i guess it even says it on his add just made for bmw and benz i will post the pictures up at night after work
Old Dec 30, 2008 | 03:53 PM
Mathmik's Avatar
I would Go with "E3202nv" way its much easier and no Splicing of your wires. if you still choose to go with the resistor install. You will need to pull your trunk liner off to get to the wires.
Old Dec 31, 2008 | 09:35 PM
blackcls63's Avatar
Just ordered the HOEN bulbs... will post pics when I get em...
tired of that yellow ugly-ness
Old Jan 5, 2009 | 12:48 PM
blackcls63's Avatar
Update:- 5 minute install, you can see the reflections of the actual bulbs at the bottom (they are reflecting off my bumper)
The one thing I did notice, is that they are a few mm smaller than the stock bulb, so it doesn't fit in the secondary clip (far left in pic1), but it does make good contact with the power clips.
Since these are regular bulbs, no bulb-error...
OEM/Stock Bulbs:-
Hoen $27 shipped:-
Old Jan 5, 2009 | 01:28 PM
khelawanb's Avatar
Looks great BlackCLS. Just bought some. Thanks for posting.
