side by side pics of 030 brakes
Old Jun 1, 2010 | 12:24 PM
deeboym3's Avatar
Hi all, I'm trying to find side-by-side shots of 030 front brakes vs regular amg brakes to see the size difference. Anyone have any? I tried to search with no luck
Old Jun 1, 2010 | 06:52 PM
cls55's Avatar
don`t have pics.,but i have them on my cls55 and they are larger than the regular one`s.
Old Jun 1, 2010 | 07:32 PM
deeboym3's Avatar
Thanks mang, we are all now fully aware of theobvious
Old Jun 2, 2010 | 04:28 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
i am also playing with disks ..
Uploaded with ImageShack.us
... this is 390 vs 360 mm , not the first 380mm 030 upgrade
Old Jun 2, 2010 | 09:32 AM
deeboym3's Avatar
^^ thanks man, exactly what I was looking for. Except do you have pics of the whole car?
Old Jun 2, 2010 | 10:56 AM
KLR CLS's Avatar
CLS63 PP
What rotors are those? Did you have to modify the caliper mounting?
Old Jun 2, 2010 | 11:16 AM
iamnsxtc's Avatar
NSX, CLS63 AMG (030), CBR600.
From the porterfield rep..search somewhere here...the only difference from a p030 and regular AMG is the rotor size is bigger the caliper is the same...The pics from Dyno show this....
Old Jun 2, 2010 | 11:44 AM
dyno's Avatar
so, not exactly:
a few ponts:
- those disks are original.
- car with 390mm is special installation. usually 390mm goes into cls63 with 6 piston calipers, while our 8piston caliper goes with 380mm.
- using same caliper you may have problems in that it ocntacts with wheel drum or spokes ..
- caliper is the same as for 360mm, BUT bracket is different.
btw, after studying all this, I am now going with real carbon SLR disks ..
ideal for me would be 370mm diameter (as the first slr) as it s not needed larger and it would just grow in weight ..
I already have a pair .. working on them (they weigh 6150gr each, hat included)
nonetheless, love also the look of new slr722 brakes in 390mm and 6 pistons...
Old Jun 3, 2010 | 11:34 PM
2K6E55's Avatar
AMGs
This is a close up pic of my 030 CLS55 brake.
Old Jun 4, 2010 | 09:30 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
Also P030 package doesent come with Two piece Directional Rotors.... and the carbon rotors.....cost a Sweet Change...
Old Jun 4, 2010 | 11:15 AM
dyno's Avatar
no, sorry, but p030 does come in 2 pieces !
p030 above appears a 380mm rotor & 20" wheel.
ps: about carbon rotor I was wrong. weird but the 390mm weighs less than the 370mm ! .. just got it at hand and it is 5750gr.
Old Jun 4, 2010 | 02:40 PM
///AMG4EVER's Avatar
CLS55 Designo 030
Good info dyno.
So, you ended modifying your 8-pot cal to fit the 390 mm rotor found in the 63 PP?
Does it really make a noticeable difference?
Old Jun 4, 2010 | 07:19 PM
dyno's Avatar
Originally Posted by ///AMG4EVER
Good info dyno.
I was interested in something lightweight and ... exotic enough
unfortunately when you go larger in dia, even with 2-pieces rotors, you get back nearly the same weight as stock 360mm disks, i.e. 15.6kgs ..
from this point of view, a good choice is CLS63 stock rotors which are 360mm but in 2-pieces
as I told before, I decided to worry only for carbon-silicon carbide.
now I'll play with these :
I have both 390 from 722 and 370 from slr : they are different produce/tecnology and that explains difference in weight.
must think about it .. maybe I'll end up putting 370mm on the rear. need to do custom support/brakets .. depends on my tech.
