Need to remove calipers - how to temporarily plug brake lines?
Caution--If you have CLS 55 its senstronic brakes. Disconnect the electrical at the ABS unit to disengage the electronics from activating the pistons and losing some fingers for the DIYer.
The Caliper bolts are single use bolts. Need to purchase new ones from your Stealer Dealer with the lock-tight pre applied.
Don't forget to also pick up the super secret MB hi temp brake pad grease while shopping at your Stealer Dealer. This goes on the back of the pad brakes between the pistons in lieu of a backer plate.
Untorquing and re-torquing these caliber bolts is a trick. So much torque makes its difficult to get the leverage without a lift. Make sure you re-torque to specs which most likely you will need to have your Stealer Dealer do for you. Since your having him re-torque these pain in the *** bolts, it’s easier for him to flush and bleed your fluid.
Good Luck and do it right the first time.
PS...My suggestion-while everything is apart, put new Zero Dust Akenobono Euro Brake Pads on. It is really zero dust and it will keep your wheels clean 100% of the time.
Untorquing and re-torquing these caliber bolts is a trick. So much torque makes its difficult to get the leverage without a lift. Make sure you re-torque to specs which most likely you will need to have your Stealer Dealer do for you. Since your having him re-torque these pain in the *** bolts, it’s easier for him to flush and bleed you fluid.
I have done brakes before on my M3 (installed a Brembo BBK) but have never worked on the AMG, so am a little nervous. I also own a pressure brake bleeding system so am comfortable with that procedure.
Thanks again
I don't have access to a car lift so the breaker bar just doesn't have enough clearance, and my impact driver isn't powerful enough ..
Painting instead of powdercoating is starting to look better by the minute!
You might want to try a little heat on the bolt head with a torch. They have locktight on the bolts threads
Good luck.
M_Berman is a wise guy. Knows what he's talking about.
And crimping a brake line that's as old as yours (if you're doing your '06 CLS) is asking for a trip to the dealer to get a new line. At the very least, you could expect to dislodge crusties inside the line and they'd travel down to your caliper and clog a passage or something.
Also, you really, really need to ensure that you don't have the Sensotrinic Brake Control before you start self service. (See below). You could shoot your eye out. SBC does some crazy stuff to home mechanics.
Best of luck!
Cars with SBC
Mercedes SL roadster (R230)
Mercedes E-Class sedan (W211) and Estate (S211) until mid 2006
Mercedes E-Class 4matic sedan (W211) and 4matic Estate (S211) until mid 2006
Mercedes SLR (C199)
Maybach 57 and 62 (W240)
Mercedes CLS coupe (C219) until mid 2006
