Dyno Mode
Old Mar 25, 2012 | 11:31 PM
Saeedg48's Avatar
2009 CLS63 AMG
Exclamation Dyno Mode
Old Mar 26, 2012 | 04:01 AM
sheepy67's Avatar
2015 S63 amg
How did you employ dyno mode on the old models?
Old Mar 26, 2012 | 04:35 AM
kbahl21's Avatar
CLK & GL
On the old cars you just had to...
1. turn key to 3rd position(right before car starts)
2. make sure the middle screen is set to Farenheit
3. turn key to first position(off position), do not take key out
4. turn key to the second position
5. hit reset button 3 times and that secret menu comes up
6. scroll through the menu till you see dynometer, turn it on then start the car
Old Mar 26, 2012 | 04:41 AM
sheepy67's Avatar
2015 S63 amg
Thanks, will have to give it ago....
Old Mar 26, 2012 | 12:04 PM
Saeedg48's Avatar
2009 CLS63 AMG
...yes that's on the old car hahah in my opening post i state that i know how to do this. does anyone know how to do this on the new cars?
Old Mar 27, 2012 | 12:04 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
i already tried it and the car goes crazy,
but to be honest, it is almost as ( ESP off ).
To access "Dynomode", please follow the following instructions and tips.
- before turning off ignition, navigate to the "mileage screen" (make sure any errors are reset)
- turn off key and close door
- do not touch any pedals or buttons other than descibed next
- put key in ignition
- turn to position1
- press and hold "answer" followed by "ok" in fast succession
- a new menu will appear on screen use left "Up & Down" arrows to navigate to "Dynomode"
- press "Ok" to enable
- turn on ignition
Old Mar 27, 2012 | 07:28 AM
Mr. Happy's Avatar
2014 Lotus Evora S
Same procedure as for the C63 then.
Old Sep 9, 2012 | 10:55 AM
rleepremier's Avatar
12 CLS63, 12 GLK350, 08 RR SPORT SC,
Is this how you get to dyno mode in 2012 also?
Old Sep 9, 2012 | 05:00 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Try it and let us know if it works.
Old Sep 11, 2012 | 12:58 AM
Incon306's Avatar
E63
I've tried the steps listed here on my 2012 E63 with no luck. Can anyone here confirm if the 2012 BiTurbo's have this feature and if so what the proper steps are to activate it?
Old Sep 11, 2012 | 07:04 AM
Mr. Happy's Avatar
2014 Lotus Evora S
I think it's something like key in position 1 (door closed), make sure that dashboard screen shows mileage display, then hold call button on the steering wheel followed by the ok button on the steering wheel and hold both for 5 seconds, then you navigate the menu.
