Hardwire radar detector 07 cls63
07 cls63
Hi all. First off, I know there are numerous threads on a DIY install of hardwiring a radar detector but I can't seem to figure out one step. I've located cigarette lighter fuse #54 on fuse panel in the engine compartment to tap into. The issue I'm having is how the heck do you get through the firewall to bring the wire into the passenger cabin? I've looked everywhere. I know some people have done this before so any help appreciated!!
07 cls63
Well, there is this thread:
https://mbworld.org/forums/e-class-w...1-install.html
but that is for an e class and I actually think the other method would be easier to do if I can figure out how to get through the firewall.
I was referring to this thread:
https://mbworld.org/forums/cls55-amg...ml#post4672488
If your using a V1 get the Savvy and stop killing yourself....
This is what I did...
https://mbworld.org/forums/cls55-amg...all-218-a.html
07 cls63
'08 CLS63
i asked the same question almost a year ago and received no help...maybe i can help...take off the panel underneath the dash and remove the parking brake lever from the cover so you can remove it (the cover). If you look in the direction of where the fuse box should be located behind the firewall you will see a big piece of foam. the wiring harness goes through the foam to the fuse box. what i did...remove the fuse box cover and set a flashlight (or shop light) on top of the fuse panel facing towards the firewall. from underneath the dash remove part of the foam until you see the light coming from the fuse box. it's fairly easy to run the wire from the fuse box towards the dash. long story short...remove the foam at the firewall and get your hands up there and fish the wire out from the engine compartment side.
hope this helps??
also...if you’re going through this trouble, think about getting a custom install detector. i have a qi45 and it was cake to install...and it's stealth. when i bought mine the 8500ci wasn’t available yet. the qi doesn't have the gps which i sorely miss (my 9500ix had it) for marking false signals and not being active below 20mph. look into a 8500ci or the beltronics. the beltronics is better but the 8500 works good and has the gps. just my $.02 worth.
good luck, john
hope this helps??
good luck, john
07 cls63
hope this helps??
good luck, john
hope this helps??
good luck, john
So basically follow these instructions but use my method to remove the cover if you have a CLS:
masterT1021 - Have some questions on your post. The 2 clips - can you see them when you remove the trim piece. I assume that the 2 wider tab holes without corresponding trim tabs are where the tabs are located. Did you push straight down but you said at an angle - angle from the side or front to rear angle. Sorry for all of the questions but I can't seem to get these two tabs to release (06 CLS500). Thanks for the post.
07 cls63
