Tire Sizes for 20 x 10.5 rear on CLS55
Old Nov 26, 2012 | 05:28 PM
zach1745's Avatar
06 CLS 55 AMG, 03 Toyota Camery (daily driver)
I have a 2006 CLS55 AMG and was wondering if a 295/30/20 rear tire on a 20 x 10.5 wheel will work?? I talked to discount tire and they said that the 295/30 tire would not work but a 285/30 tire will.
Any thoughts/opinions is much appreciated
Old Nov 26, 2012 | 09:22 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
You can put a 305 if you want...285 would be perfect but you can run bigger, it will look bulgy, thats all
Old Nov 26, 2012 | 10:43 PM
Vic55's Avatar
Administrator
you will be fine with a 295x30x20 on a 10.5 wheel...
TireRack uses this width (wheel wise) when listing its specs on that size tire.
If you ran an 11 it would be slightly stretched (just saw my buddy run a 295 on an 11) and on a 10 it would create a slight bulge as Rabbi said.
Now in regards to the CLS application- are you lowered?
Old Nov 26, 2012 | 11:17 PM
zach1745's Avatar
Vic55, my car is stock as far as suspension, but i do roll around in SportII mode unless im taking a road trip and then ill set the suspension to comfort mode. I looked under at the rear tonite and it looks like it should clear. I currently have the stock 19 x 9.5 with 285/30 on the rear.
Old Nov 27, 2012 | 12:25 AM
M1RAG3's Avatar
CLS550 AMG Pkg.
I am running a 305/25/20 on my 10.5" rear...I can slam the back -1.8" inches with no rubbing (this is my normal setting), even with the 305. IMO - it does not look chunky, it looks perfect on the 10.5" wheel.
Old Nov 27, 2012 | 10:03 AM
Vic55's Avatar
Administrator
Yes you will be fine at stock height...
Old Nov 27, 2012 | 04:09 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
I run a 305 on a 10.5" wheel and the fitment is perfect. It all depends on the tire brand. Some tires have a wider section width as compared to others.
R.K.
Old Nov 27, 2012 | 04:50 PM
swiftvision's Avatar
NSX
What tire sizes should I run for a 20x8.5F and 20x10" rear?
Old Nov 27, 2012 | 05:06 PM
radride's Avatar
^^245 on the front and a 285 out back.
R.K.
Old Nov 27, 2012 | 06:37 PM
val69's Avatar
Chevy Cavalier(206,000 miles)
255 and 305
Old Nov 28, 2012 | 07:26 PM
NSX
R.K.
There are very few 285/25/20's out there....
In fact I can't find anything other then the Han. V12's in those sizes.
Even with the 255/30/20 and 295/25/20 size I can only find a few.
Old Nov 28, 2012 | 11:35 PM
abl2fly's Avatar
CLS55 AMG
305 is the way to go for a 10.5.
Old Nov 28, 2012 | 11:41 PM
radride's Avatar
The Hankook V12's are a great tire.
R.K.
Old Nov 30, 2012 | 01:59 PM
NSX
R.K.
Not in my experience. It's a budget tire for a reason.
Old Nov 30, 2012 | 02:02 PM
radride's Avatar
You might want to read this then:
http://www.caranddriver.com/comparis...12-evo-page-10
R.K.
Old Dec 5, 2012 | 01:38 PM
hoolamonster's Avatar
CLS55
The V12's are nice tires they are controllable, have grip and a good tread profile for the CLS. Most likely people trashing them have not used them. Tires are limited in 20's. BTW I could prolly fit a 315 on my CLS.
