CLS55 Flush wheel fitment advice...
Old Dec 2, 2012 | 02:53 AM
Flo1989's Avatar
CLS 55, Audi A7, Range Rover Sport
I'm looking to get a set of 20" concave wheels for my 55, (20x9 and 20x10.5) but I want to make sure I get the right tire size and offset. Not too familiar with offsets so I wanted to check w/ you guys (& girls) who are knowledgeable in this area..I'm currently running a stock suspension setup and do not plan on lowering the car unless theres just too big of a gap b/t the wheel well & tire. And if so, it would only be dropped slighty. No slamming. Anyways, I was thinking of going with a 255/30/20 and 305/25/20 tire. My main concern is the offset. I was told the wheels had an offset of +24 front & +28 rear. Great/Good/Bad? Will I have to do any mods? I want a flush fitment look. If these numbers are no good, what should I strive to get then? Help pleeaase. And if anyone is running 20" on a stock supension via 55/63, please post a pic so I can get an idea of what it looks like...Thanks in advance
Old Dec 2, 2012 | 03:15 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
https://mbworld.org/forums/wheels-ti...7r-sl-cls.html
https://mbworld.org/forums/wheels-ti...ec-sl-cls.html
Both sets I'm selling are perfect fit for CLS stock or lowered.
Old Dec 2, 2012 | 02:10 PM
Flo1989's Avatar
Nice wheels but I already have the wheels picked out that I want...I just wanted to get help with the offsets with the given tire size........
Old Dec 4, 2012 | 03:08 PM
M1RAG3's Avatar
CLS550 AMG Pkg.
Those offsets are good.
I am running +25 in the front on a 20x9, with a 10mm spacer and extended lugs and it is flush. My tire size is 255/30/20
In the rear I am using +27 on 20x10.5 with no spacer. Tire size is 305/25/20. I do not have any rubbing issues, even with a 2.0" drop in the rear.
Here is an example of a 55 AMG with 20s and no lowering.
http://www.flickr.com/photos/rayco2n...n/photostream/
With such a lower profile tire, you are definitely going to want at least a moderate drop to have your car looking good.
Old Dec 4, 2012 | 06:46 PM
Flo1989's Avatar
Thank you very much for that info + pics...To my surprise, the 20's dont look too bad on a stock suspenion. I actually found out that the overall height of the 20's with the given tire size are the same as the stock 19s. The tires on your car in the stock suspenion pics are the 255/30 and 305/25 correct? And what lowering method did you use?
Old Dec 4, 2012 | 07:43 PM
CONCAVO's Avatar
Former Vendor of MBWorld
Mercedes Benz CLS63 AMG
You can go with a 20x9 et24 front and 20x10.5 et25 and you can run a 255-30-20 and 305-25-20. No fender rolling and NO RUBBING. Hub centric / Big brake friendly. Here 3 shots for you.
Old Dec 4, 2012 | 08:33 PM
Flo1989's Avatar
Thank you for that info + pics...is that car lowered? It looks like it is the back but uncertain for the front...
Old Dec 4, 2012 | 08:45 PM
CONCAVO's Avatar
The 63 was lowered with adjustable links. The customer didn't want it that low because of the front lip and the snow in Canada.
Old Dec 4, 2012 | 09:04 PM
Flo1989's Avatar
Exactly how I feel; Ohio weather plus front lip. Thanks again
Old Dec 4, 2012 | 09:14 PM
CONCAVO's Avatar
Anytime.
Old Dec 5, 2012 | 11:37 AM
M1RAG3's Avatar
CLS550 AMG Pkg.
The car in the picture is not my car. I just pulled it off the internet as an example of stock height + 20s. It looks like a 295/30/20 in the rear, because I can see a bit of stretch.
this is my car:
http://i1171.photobucket.com/albums/..._1001-edit.jpg
the front is -1.8" and the rear is -1.6" in the picture. Just note that the 63 AMG suspension sits approx. 0.5" lower from the factory than does my 550 suspension, based on what I've read. I am using a Programa lowering module which is fully adjustable between 0 and -2.0" from stock height.
