CLS55 & CLS63 Light Weight Two Piece Rotors from RacingBrake
Old Sep 27, 2013 | 04:25 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
RacingBrake has the finest quality two piece rotors for your CLS's
Front Non Perf. pkg
Front w/Perf. Pkg
Rear
MBWorld members receive free shipping to the lower 48 states using coupon code
MBW-SHIP!
offer valid until the end of June.
These rotors are engineered to be the best stock replacement two-piece rotors on the performance market. These rotors are direct bolt-on, easy to install, no additional hardware needed, and an excellent upgrade for both streets and track. Not only will the rotors last 3, times or more longer than competitions' two-piece rotors, they can deliver consistent brake torque under extreme heat, session after session. When it comes to replacement, the operating cost over the time will be lower than one-piece rotors.
RB offers a complete satisfaction guarantee to you and other MB enthusiasts; if you don't agree that they are the best two-piece rotors in value, look and performance your money can buy just return them for a refund.
• Has the advantages of both drilled & slotted rotors.
• Allows the disc to expand and contract and prevents the disc from cracking or warping.
• Increasing cooling area and retains more friction surface.
• Slots relieves thermal stress.
• Slots are self cleaning and the pad build up will not clog the slots and are exhausted via the rotor edge keeping the disc surface clean.
• Reduces brake pad dust buildup and keeps the wheel clean through vacuum effect.
Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated
Machining: Straight Slot
Surface: EDP Coating w/cross cut grinding on friction surface
Racingbrake Technology
Browse our complete two piece rotors offer for MB:
http://www.racingbrake.com/category-s/7136.htm
Check out some of our reviews
World's First: RacingBrake 2-Piece Brake Rotors
https://mbworld.org/forums/sl-class-...squealing.html
https://mbworld.org/forums/sl-class-...ml#post6057706
http://www.e90post.com/forums/showthread.php?t=474395
Old Jun 25, 2014 | 07:10 PM
CLS550
Free shipping offer is ending soon!
be sure to place an order before the end of June.
