Any other Twin Turbo CLS55's out there?
Old Oct 6, 2015 | 09:20 PM
  #101
Stiffmeister's Avatar
2006 CLS 55 AMG twinturbo
Thanks. It would be nice find out exactly what all has been done to this car already....but it seems those people don't care.
It will be a while till I can get started. Do you know anyone running e85? I'd like to know what injector/ECU setup they are using. In my Nissan, I went with 1300cc Injector Dynamics because 740cc Nismo could not supply enough. This appears to have 550cc injectors (based on the the profile signature of the previous builder).
Not sure it's even worth building the bottom end if I keep the tune for pump gas.
Old Oct 7, 2015 | 06:00 AM
  #102
StuttgartAMG's Avatar
E55 AMG (W211)
Originally Posted by StarvingArtist
[...]the transmission can be rebuilt to handle 1000hp no problem. [...]
LOL!!!!
The stronger 722.649 (SL65 Transmission) is not really able to handle 1.000hp.
Why should this be able at a 722.643!?
Old Oct 7, 2015 | 07:57 AM
  #103
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I was under the impression that they are mostly the same minus double sided discs that can be added. The rebuilders know what to do, I don't. I just read about it and decided to leave it to the professionals who know what they are doing.
Old Oct 8, 2015 | 04:35 PM
  #104
blackbenzz's Avatar
haters crazy
Originally Posted by StuttgartAMG
LOL!!!!
You can build a 722.6 to handle over 1000hp. You don't have to use factory parts if that's what you are implying
Old Oct 8, 2015 | 06:16 PM
  #105
Mike450's Avatar
2015 gl450
Problem with the 722.6 is not necessarily handling the 800+ torque physically, the issue becomes having the TCM shift when you want it too.
Anything above 800whp/TQ starts to throw fits at the 722.6, at least in the srt8.
Old Oct 13, 2015 | 05:39 PM
  #106
Well I think I have figured out proper 4" K&N filters to fit directly onto the turbos. I will also order/install Kleeman cams. After that, drive to Los Angeles to have removable pipes for cats/no-cats. LaBree motorsports will be making a custom exhaust. I'm very impressed for what they made for my 300zx twin turbo project. All my piping looks like this (except I have dual tips)
https://schuss.net/?page_id=5917
Then we'll run her on the dyno at SpecialtyZ.
Old Oct 19, 2015 | 06:35 PM
  #107
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Those cams are probably a waste Of $$ for that car
Old Oct 19, 2015 | 10:05 PM
  #108
I assume that comment is based on facts? Please send me the links to any before/after dyno results using the super sport cams.
Old Oct 20, 2015 | 08:20 AM
  #109
AndreNY's Avatar
couple of Benzos
big waste of $$$$
Old Oct 24, 2015 | 03:02 PM
  #110
Before/after camshaft dyno from Kleeman
Attached Thumbnails Any other Twin Turbo CLS55's out there?-before_after_cams1.jpg
Old Oct 24, 2015 | 06:35 PM
  #111
Ok so the people who sell it say it's awesome and you should buy it? By all means then ..
wtf do I know
Old Oct 24, 2015 | 10:42 PM
  #112
Sir-Sarcastic,
I recommend that you email Claus to voice your concerns about his product. All you have to do is go to the Kleeman website. Unfortunately, I do not feel comfortable posting his email address on the forum.
These forums ????
Schrick makes cams for NA M113, the M113K
Will lose power with these = Down grade.
Even Schrick in Germany send me customers.
Ours are made as an upgrade to M113K, see Dyno.
Med venlig hilsen/Best regards
Claus Ankjær
CEO, founder & owner.
Old Oct 27, 2015 | 03:28 AM
  #113
Hey. I was offering some solid advice to you with nothing for me to gain or lose by whatever you do. If your engine was already removed from the car and being built and the cams were a few hundred $$... By all means , why not. But your application is so far beyond the scope of what was in mind when those cams were designed that any silly little graph you've seen (for marketing purposes only) has exactly zero relevance to your specific car.
If you've seen the specs on those cams and know what the stockers spec out at, and know what a turbo engine wants in contrast to a supercharged engine, they're so close to the originals that it's barely worth the time materials to swap them even if they were free. But I nor anybody here will stop you from lighting your cash on fire so please proceed.
Old Oct 27, 2015 | 08:13 AM
  #114
AndreNY's Avatar
couple of Benzos
I think the best thing for the OP is to spend $2500 on the cams dyno the car and post results
Old Apr 13, 2016 | 02:34 PM
  #115
Finally picked up the CLS55AMG tt conversion and am currently driving cross country. Unfortunately, we fried the tires during MotoGP weekend in Austin, TX. Now have one flat and one bald tire while stuck in Sonora, TX.
Anyway the motor is toast. I think there is more blowby at idle than exhaust coming out the pipes. The body and interior is fantastic. It has Forgiato 20" rims all the way around. Waiting on 305/25-20 Nitto Invo's to arrive at the hotel I'm stuck at.
Would still like to hear from the original owner of this thread regarding the mods & electronics. Did not know it had methanol/water injection. Ice tank in the back, very nice. I was able to get air filters on the car. I believe the turbos are good as they don't have much play and do not hit the housings.
http://www.burgertuning.com/single_t...er_by_BMS.html
Old Apr 13, 2016 | 08:49 PM
  #116
Mike450's Avatar
2015 gl450
I lol'd at the blow-by at idle comment.
Good luck dude. Awesome looking car.
Just remember before you dive into a rebuild, a 600-700 whp reliable car is 100x's more fun than a sketchy 1000whp car.
Old Apr 16, 2016 | 09:13 AM
  #117
While your engine may very well be toast as you say, don't automatically assume so just because there's smoke coming out the tailpipe. Mileage combined with excessive exhaust backpressure may have killed your valve seals, also lack of a properly functioning crankcase evac system will make the best of engines smoke like a chimney.
Do a leakdown test (not compression) to be sure, and don't beat on it while it's burning oil as the oil is going to make it detonate like a ***** which will definitely result in a fragged engine.
Old Apr 16, 2016 | 09:20 AM
  #118
Also more fun facts, never pose with your car in any way whatsoever.
Blows the needle off the douche gauge unless you are both beautiful and female, which you are neither
Cool car though, I wish you the best with it and will help you get it in action any way I can.
Old Dec 4, 2018 | 09:18 PM
  #119
The car is toast. It burned up on Nov 8th, 2018 during the Camp fire in Paradise California. Words can't express how devastated I am. We haven't been allowed back into Paradise yet but my fire fighter buddy sent me pics of both my cars and my four motorcycles....all toast.
Old Dec 6, 2018 | 08:43 AM
  #120
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
**** that is Terrible man, really sorry to hear. Certainly one of a kind. Good luck with moving forward and chin up brother man. Again so sorry to hear of your losses
