Front rotors
Old Jan 22, 2014 | 11:36 AM
Bossman1340's Avatar
cls 63 amg
Front rotors
Whats the best place to buy front rotors for 08 Cls63
Old Jan 22, 2014 | 12:53 PM
cm60k's Avatar
*For OE replacement, you can go with AutohausAZ,
http://www.autohausaz.com/search/pro.../Brake%20Rotor
*for best performance with less fade & less weight, you can go with RB racing brakes, its one of the best choice,
http://www.racingbrake.com/category-s/7136.htm
ZAYED,,
Old Jan 24, 2014 | 08:55 PM
Og Asr's Avatar
2008 CLS 63 amg
www.oediscountparts.com......rotor is $750.00 each for the MBZ OEM.
http://www.oediscountparts.com/parts...w=11&maxRow=10
Old Jan 25, 2014 | 10:43 AM
Manofsteelpt's Avatar
Veteran: Army
S63
Are the oem CLS63 rotors 1 or 2 piece? Anyone have thoughts on the Girodisc lightweight 2 piece rotors?
Old Jan 26, 2014 | 03:42 PM
cls 63 amg
front rotors
Thanks for the info
Old Feb 5, 2014 | 10:31 PM
Og Asr's Avatar
2008 CLS 63 amg
Thanks for the info
Just ordered mine from OEdiscountparts.com
$1748.....for rotors, pads, and sensor. I also ordered new caliper bolts which I don't need to change...but just wanted new bolts in there....$5.00 each...total of 2 for each side.
Old Feb 5, 2014 | 11:25 PM
cls 63 amg
Imma take a look thanks
Old Feb 6, 2014 | 12:57 AM
TWF63's Avatar
07 cls63 amg, 09 R1
Anybody used this rotors/pads?
Stock ones work great, until you hit race track
Old Feb 23, 2014 | 01:22 PM
Og Asr's Avatar
2008 CLS 63 amg
Finally installed my brand new rotors and pads....it was a piece of cake. You just need a tool to punch out the pins that hold the brake pads. Also before removing caliper make sure you suction out some Brake Fluid from the reservoir prior to using a screw driver to press the caliper back in with using the old brake pads as your cushion.
Once you use a screw driver to press back the caliper...the new rotors and pads fit with ease.
Total price...$1827...for parts.....you only need one brake pad sensor for the passenger side....I actually changed the caliper bolts...(4 21 mm bolts)...piece of mind...and torqued to 133 foot pounds or 180 nm.
Had to continually bang the rotor to eventually come off the hub lol....but you just have to put some wd-40 to loosen it up.
Hope this helps.
Old Jul 2, 2014 | 04:13 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
RacingBrake offers direct bolt on front and rear light weight two piece rotors for 07-11 CLS63 AMG's. Our rotors are compatible for both street and track use and can be used with your current brake pads. Although, we do recommend going with our brake pads for the perfect combination. With our ET500 street brake pads, you will have great bite with no squealing!
Weight
Front Two Piece Rotors
OE One-piece 36 lbs.
OE Two-piece 29 lbs.
RB Two-piece 24 lbs.
Rear Two Piece Rotors
One-piece 21.5 lbs.
Two-piece 15.5 lbs
Shaving a complete total of 36 lbs. of unsprung weight compared to OE's one piece rotors, improving your handling and steering response.
We also offer the option to purchase replacement rings for our two piece rotors, saving you a fraction of the cost when its time for a rotor replacement.
Check out some of our reviews
World's First: RacingBrake 2-Piece Brake Rotors
https://mbworld.org/forums/sl-class-...squealing.html
https://mbworld.org/forums/sl-class-...ml#post6057706
http://www.e90post.com/forums/showthread.php?t=474395
to learn more about our features click here
Old Jul 4, 2014 | 01:32 AM
cls 63 amg
Front Rotors
I finally got my front rotors from racing brakes.com for my CLS the rotors and their customer service is AWSOME. Great product and a good company to deal with. HIGHLY RECOMMENDED
Old Jul 18, 2014 | 01:16 PM
CLS550
Thank you Bossman1340!
We look forward to hearing your feedback.
Enjoy your new RB two piece rotors!
