Max speaker depth?
Old Mar 31, 2014 | 07:54 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
ciao Kelvin,
left door is the same as passngr's
yes, obviously I had to relocate the mirror's controller
it was a very debated issue where to relocate it ..
if you want to know the whole story:
for example this guy put it here, above the armrest, but I did not like that
best would have been to have that controller integrated with the other buttons on the arm-rest, as other Mercedes cars have (C204 and other newer cars) ..
I looked into that possibility but the buttons of our car have a particular shape and would not have been nice..
Maybe the best feasible solution would be to replace our light switch on the dashboard and replace it with one from CLK (or something like that. .. don't remember correctly) who integrates the mirror controller into thelight switch ..
That would have required to mod somehow the dash housing to fit it into.
As I did a lot of work on my dash because my bottom side was upholstered with alcantara , we could have done that mod also ...
unfortunately the idea of using that clk switch ( or G-class and SL-class switches) came late, when the upholsteirng work was already done ..
btw, I also upholstered in Alcantara the back of front seats and the small drawers
considered also the possibility to make an openable device like the rear door ashtray ... but indeed our mirror switch is a really big thing.. and my installer was already tired,
so in the end I found, as a somehow temporary location, the solution to fit it close to the trunk switch, into the door bottom pocket.
Not extremely comfortable but, as I use it so rarely, it is still there
Old Mar 31, 2014 | 08:27 AM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
What a beautiful clean job mate, with lots of time and thought gone into it making it a very clean build.. B-E-A-UUUU-Tiful
Old Mar 31, 2014 | 11:12 AM
dyno's Avatar
thanks Owner for compliments and for understanding !
then, besides appearance, the real challenge is to get everything working good.
these cars are designed as a whole system and when you modify something the system does not like that ...
you have to go into understanding how eveything works.. then, to think at some "safety" measures ..
The most challenging one was not fitting my 6 amplifiers. it was the sixth of them, a Class A who is sucking 16ampheres at IDLE .. producing so much heat... even disturbing my battery control module during the hot season .
I 'm thinking in these days at the last mods to be done: a special venting system and.. to be able to start the car using just the front batttery.
btw, Guys,
you did not tell me anything about the "protection film on rear sides"
that I modded a few weeks ago and is posted here:
https://mbworld.org/forums/w219/5337...ear-sides.html
do you like more dark or clear ?
.. see what nice black thing next to my car that arrived while I was at my service for fitting those films and other things
Old May 15, 2014 | 08:14 PM
dyno's Avatar
Originally Posted by Kelvin07
I just ordered a pair! , my installer says he can modify my door panel an re-use my OEM grille to cover the speaker, I SHOWED HIM PICS OF YOUR DOOR and how they looked and I told him "that's what I want!"
Dyno, what crossover points are you using for your speakers?
Are you using center speaker?
After reading your comments, I am also planning on replacing my stock tweeters, with something that can play lower frequencies (around 2khz).
.. just bumping
so, Kelvin, did you get those speakers ?
Old May 15, 2014 | 08:18 PM
Kelvin07's Avatar
CLS55 AMG, ML63 AMG, Cayenne S
I did, very easy install on the front doors, I will take pics so you can see, it looks OEM.
Dyno, when they installed your 4" mid ranges on your door panels, did they have to cut some metal to make the fit?
Old May 15, 2014 | 08:32 PM
dyno's Avatar
yes, they did a small cut for hosting a side of the magnet.
btw, I placed the carbon morels on front doors and .. should have put there before ..
lately I am playing with high-def audio in 24bit-96KHz sampling rate and these speakers are really great for playing strong basses.
.. waiting to see your door install
Old May 15, 2014 | 08:35 PM
  #32
Kelvin07's Avatar
This is how it looks right, still a work in progress, any advice will be greatly appreciated
Old May 15, 2014 | 08:37 PM
  #33
Kelvin07's Avatar
I meant this one... The little speaker. Did they have ti cut the metal behind the door panel to make it behind the grille?
Old May 15, 2014 | 08:38 PM
  #34
Kelvin07's Avatar
Correction, my installer told me it was a very meticoulius job to make it fit strong and tight.
They are not an audio shop, they are an upholstery shop, they will do the alcanatara on my roof and pillars.
Old May 15, 2014 | 08:47 PM
  #35
dyno's Avatar
I got it right .
again, yes
your mid bass install seems Ok .
too bad that you can't see anything hrough the stock cover grille ..
  #36
Kelvin07's Avatar
Thanks!
Old May 15, 2014 | 08:50 PM
  #37
dyno's Avatar
.. found a pic for you
here you see the cut
but it was during the progress, so don't take it as final
Old May 15, 2014 | 08:55 PM
  #38
dyno's Avatar
if they modded the fitting of the grille you have to check for vibrations when pushing volume up ... it's a very critical point
Old May 15, 2014 | 09:10 PM
  #39
Kelvin07's Avatar
Absolutely, they have taken that (vibrations) very much into consideration, they have reinforced the grill and the door very much and I still want them to work on that grill a bit more because I think it could look thinner and more flush.
Thank you for the picture!
Old May 15, 2014 | 09:26 PM
  #40
dyno's Avatar
know this one, nice view
.. did you get passenger's auto-dimming mirror ?
Old May 15, 2014 | 09:59 PM
  #41
Kelvin07's Avatar
Which one is that?, no idea if I have tbh...
Old May 16, 2014 | 08:06 AM
  #42
dyno's Avatar
Electro-chromic glass
the Electro-chromic mirror glass for the passenger's side comes only as special option (very expensive).
it makes the same auto-dimming function as the driver's and center's: when a light hits the mirror and the intensity of that light is stronger than the lights the car is receiving from the front then, the mirror automatically dims ..
see post #33 (or #10 )
in that photo my car is receiving strong sunlight from behind, while the front of the car is still inside the dark of the garage: you can see that the glass is getting darker (just compare the boundary of the glass, where the electrochroming thing does not work, which keeps staying standard light colour ..).
I had that option in my former version of mirror housing but when I installed the 2009 mirror version they did not fit me the same optional glasses and I soon noticed that, for example when somebody from behind you is hitting lamps or just has annoying high lamps on.
with these glasses those stupids are immediately darkened out ..
Btw, if anybody's interested I still have the passenger's auto-dim glass of the former mirror housing , besides also the normal glass for the new housing style ..
Old May 21, 2014 | 06:48 PM
  #43
Kelvin07's Avatar
Update: 4" mids hybrid audio installed
Old May 22, 2014 | 04:23 AM
  #44
dyno's Avatar
ahah .. Hybrid audio, you mean HAT by Buwalda ? ..I talked with him some years ago. His goods are very well reputed.
Job appears good !
but next time post bigger and more pictures .. also of the mid-low, without grille
btw, did your shop fitted it without having to remove and cover again the door panel with leather ?
bet there are a lot of work-hours counting ..
... just remember when my installer told me the counting for the major install in my car and it was more than 300hours ... beware
