'07 CLS 550 crank but won't start and is not the Crank Shaft Position Sensor
OK, so last Sunday I went to start the car after parking at the mall for 2 hrs. and it would crank and crank but wouldn't start. 5 mins later I gave it another try and it fired right up. So, I thought to myself it must be the Crank Shaft Position Sensor as my car has 48,000 miles on it and has never been changed. I took it to my mechanic and he thought it was the CPS also, so I had he changed it out on Thursday. Everything was fine until today it did the same thing!!! This time though the crank didn't sound as strong as the first time it happened. So, I waited a few minutes and gave it another try and it fired right up! BTW, I already took it to a battery specialty place and they checked my battery and they said it's still very strong. What could it be then if it's not the CPS??? Anyone had the same problem before? Any input is very much appreciated.
If the car doesn't have an aftermarket tune the coding is not the problem. The fact your "mech" thinks it is makes me question his competence.
I tried taking the rear seat out but got stuck after popping the clip close to the door. So, to release the side close to the center I just yank it out? It seems pretty tight and I don't want to break anything.....
Pull it straight up, you can bend it if you pull it out crooked enough, no big deal, bend it back.
