need advice ASAP, idler puller just went
Old Jan 10, 2015 | 07:43 PM
whyask's Avatar
CLS55 AMG
Its the Tensioner Pulley that siezed up on me, OK guys so this is my only vehicle , single guy, i work this whole weekend, see the damage below, is it possible to still drive it since no damn shop is open or has the parts in stock , new 8 rib belt and tenisioner pulley.
Old Jan 10, 2015 | 08:04 PM
whyask's Avatar
CLS55 AMG
This is the tensioner pulley that went !
Old Jan 10, 2015 | 08:55 PM
sexyxe's Avatar
04 E55
Only car?
If it was my only car, and no other choices, and it was just the SC belt. I would drive it in case of emergency - to the shop to buy a new belt or work, but that would be about it.
Old Jan 11, 2015 | 01:13 AM
Rocman8's Avatar
E55
No problem to drive it. Just make sure to get the pieces of the belt out of the way from moving parts. You may get a check engine light for "mechanical supercharger fault". Just clear it once fixed up.
Old Jan 11, 2015 | 04:16 AM
JoeNobody's Avatar
Mercedes
Yeah just drive it without the belt! Just don't floor it like a fool to keep it behaving well.
Get a metal idler pulley from Shardul on here. Those factory plastic pulley's blow up all the time.z
Old Jan 11, 2015 | 08:46 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Thank you PM sent
Old Jan 12, 2015 | 07:19 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
Absolutely. Drive it but don't get crazy with it. And remove the parts and belt pieces so it doesn't damage the other belt. Would suggest you pay close attention to the condition of all the pulleys. If one went the others are worn and if it has that "washing machine" sound on startup be warned bad things are about to happen. Cost me 1100.00 for the OEM parts from the dealer and installed them myself. But now it sounds like a Mercedes not a Maytag.
Old Jan 14, 2015 | 04:15 PM
Alander's Avatar
CLS 55 AMG W219
You can change just the bearing !
I put a high speed SKF 6303 ZZ bearing in mine, cost's about $8 dollar !
You need a press, so you can pop out the rivets, and press them in place again !
Or you can buy just the whole wheel new for $58 dollars. Link to ebay, I bought a spare one =):
http://www.ebay.com/itm/181154392504?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Or you can buy a Aluminium of Shardul here on the forum =)
Best Regards
Ålander
Sweden
Old Jan 21, 2015 | 11:08 PM
whyask's Avatar
CLS55 AMG
Ok first off i have to give thanks to Shardul for getting me the pulley in less than 24rs ! OUTSTANDING will be doing buinsess again ! now on to the fun part ! After 4 hours of tearing into my engine i realized the previous owner installed M113K Modular Crank Damper, 180mm package, 6 belts later we finally found the one that fits ! not knowing what size belt sucked .... ended spending more money on belts than the part... such as life ! Have to pay to play !!!
Old Jan 22, 2015 | 09:37 AM
shardul's Avatar
Glad you got the issue sorted out!
