Is there any warning/indication when air pump relay sticks causing dead battery?
Old Feb 20, 2015 | 01:43 PM
popeyebedford's Avatar
2006 CLS 55 AMG
Regarding the posts about the air pump that keeps the four corners of the Mercedes Benz level. Apparently on occasion (not too often I hope) there is a relay that will stick and cause it to drain the battery even when the key is off. Wow! that is not good...
For anyone to whom that disaster has happened. Was there any indication that something was wrong. Could you hear clicks or humming or any sound that would warn of the battery being under a load?
Was there anything odd that could be detected by an owner in their garage to indicate bad things were about to happen to your battery?
Thanks very much ... Popeye
Old Feb 20, 2015 | 06:57 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
Would suggest to get the codes and post.
