ND-Photo.nl's 2005 CLS55 Build thread
Rating: Thread Rating: 3 votes, 5.00 average.
Old Jul 4, 2022 | 07:00 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Originally Posted by bbirdwell
Just got here...it's a holiday here! Feel free to post a link in the E55 section; lots of similarities between our cars so your work may be of interest to others hanging out there.
Happy 4th! Will do, thanks for the tip
Disconnect the battery when using that wrench on the motor mounts. The extension from the ratchet will get very close to the hot lead on the back of the alternator. One touch to the hot lead and your life will get very exciting.
Havent read this tip till today, much appreciated. Will be doing motor mounts soon, but I feel that I am procrastinating instead of taking it on full steam ahead
On my car I went with Arnott rear air springs. No external tank for "comfort" mode but it is "don't care" for me. I recommend you use very heavy duty and wide clamps on the connection to the hose to the external tank.
Thanks for the tip, I used 2 thinner clamps, but 1 wide is probably better.
I recommend rotating the rear tires side to side regularly. The right rear spins first under acceleration until the traction control applies the brake on that corner so the inside of that tire wears first. It looks a lot like incorrect toe-in but it's the tire spinning. So...swap side to side regularly. And watch the inside of the front tires for signs of incorrect toe or suspension issues. If the rubber tread blocks start looking "peeled" or "chunked" you need to find and resolve the issue.
I wont be swapping it with these wheels, as they arent asymmetric afaik. The front tyres have higher inner wear (due to lowering). When I overhaul the front suspension, I will look into the arms with camber adjustment (and rose joints).
If you are looking for a Xentry system, contact BenzNinja via PM here on the forum. He's located in France so at least you'll be in the same time zone and not 6 or 7 hours apart like I am.
Ah cool, might PM him anytime soon.
On your coolant expansion tank, try grabbing and rolling the edges of the tank using a thumb and forefinger. If the plastic crumbles, it is time for a new tank. I recently did this on both my '99 and '05 E55s. Not very expensive. I paid $40 US for the coolant reservoir and another $22 US for the labels.
--AMG label A000-584-26-11
--High pressure label A210-584-07-21
It started to crumble on me, so definitely will be doing an overhaul. Want to do the waterpump at the same time, in combination with a coolant flush. As it probably was never changed....
If you ever have to replace the water pump, that is the time to pull the alternator (much easier with the water pump out!) and have it rebuilt or at least to replace the voltage regulator.
Cool, good to know!
Now...it is time for a cold beer here! Cheers!
I dont drink alcohol anymore, but any soda will do haha
Edit: your photos brought back some good memories of a time on leave in the Netherlands. I was stationed in Germany and spoke German pretty well. Knowing Dutch and German were very similar I was speaking German to a fellow there and he was speaking Dutch to me. All is good and then I turned to my then-wife and was speaking to her in English. The fellow blurts out, "You speak English!". To which I blurted out, "You speak English!". We both then proceeded to have a laugh about it... Good times indeed.
Indeed, currently the gas prices are lower in Germany. So when I need to fill up the AMG, I drive around 20 mins just over the border. I dont know if you have seen it, but the Aral gas stations have RON 102 gas at the pump In the Netherlands, we get RON98 (aka E5) tops. But the everyday driver use RON95 with 10% ethanol added)
Old Jul 4, 2022 | 07:20 PM
Might have to put this color on my wishlist...Noticed the color on the YT channel of FisherFAST
Do you think that will look good on a silver CLS?
Old Jul 4, 2022 | 07:56 PM
karlward's Avatar
2005 E55 AMG, 2007 E550, 83 380SL and Many Jaguars
Awesome build. I got here through the W211 forum. Excellent car.
Old Jul 5, 2022 | 06:28 AM
Thanks @karlward !
I also had issues with broken cables in the latch mechanism. As I went on investigation, I noticed that the previous owners already made some repairs in that department. In my case, a couple things werent functioning:
  • Boot handle
  • Auto Close button
  • Lock button
  • Boot light (intermittent)
Fixed it with some cable extentions, also applied a new ring of velt (?) tape. I made sure that the cable is able to move freely (less strain on the brittle cables)
Old Jul 5, 2022 | 06:30 AM
Invested in well known Bosch 010 pump. When I replaced it, the CLS already had a 010 pump fitted.But I have no idea how long its already there, so I swapped it anyways.
Partnr: 0392022010
Old Jul 5, 2022 | 07:56 AM
I became 40 years old on the 18th of may, the day my mid life crisis officially began
Old Jul 5, 2022 | 08:27 AM
  #32
God I love the sound of this car
Old Jul 5, 2022 | 11:37 AM
  #33
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
Lovely build thread, and kudos on keeping the car in top shape!
Can agree with the previous commenters, to disconnect the main battery, when doing motor mounts. I changed my headers and and one gasket fell on the starter and caused some sparks.
Might be worth it to get the firmer CLK63 Black Series engine mounts instead of the stock engine mounts, since those wear out quickly.
Also make sure, your fuel system is working properly. Neglected maintianance has caused quite some M113k to break. The E63 brake discs aren't worth it in my opinion, unless you really want the reduced unsprung mass.
Old Jul 5, 2022 | 12:47 PM
  #34
Thx!
I already bough the engine mounts, so when these go, then I will consider the Black series mounts.
The E63 brakes is purely for reducing unsprung mass. The standard brakes suffice for my driving style. Was looking into upgraded pads, but couldnt find all that much in Europe to be honest...Any tips?
Regarding the fuel system, I am highly aware of it now. Makes it all the more important to restore it to tip top shape, before adding power.
Old Jul 5, 2022 | 12:48 PM
  #35
Small repair, which makes all the difference. New bonnet struts! I dont get it when people skimp out on these...
Old Jul 5, 2022 | 12:56 PM
  #36
I personally use Jurid pads, people seem to have issues with Brembo pads here.
Old Jul 5, 2022 | 01:50 PM
  #37
Do you have the Jurid partnr by any chance?
Old Jul 5, 2022 | 01:58 PM
  #38
Replaced the Airmatic compressor with a new one. The air hose ruptured as soon as I touched it...Also replaced the Airmatic air filter with a new one (Mann filter). Still have to replace the rubbers, didnt know they were in bad shape.
Looked better than expected. But paper gets hard over time, so not a bad idea to swap it out
Swapped it out with an aftermarket part, which had a somewhat different layout. Unfortunately the air nipple was in a different place, so I decided to extend the existing airline. But I found out the hard way, that normal silicone vacuum hose cannot withstand 14 BAR :P
Hose said bang bang
Used reinforced vacuum hose, problem solved!
Old Jul 5, 2022 | 02:26 PM
  #39
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
https://shorturl.at/ahAIU
Amen, brother! I finally replaced mine after the hood kept falling on my head whenever I was working on the engine.
Something I forgot to mention about the motor mounts. The one on the driver side is much easier if you drop the steering rack from the subframe and lift the engine a couple of inches. You can then insert the driver's side motor mount on the passenger side and slide it across the front of the subframe to the driver side. You don't need to remove the steering rack, you just need to undo the bolts and let it drop down a couple of inches.
It's very nice to see what you are doing to your car! Please keep up the great work and continue to keep us updated!
Old Jul 5, 2022 | 07:12 PM
  #40
I have seen that tip on Youtube, good to hear that you also used the same method
Old Jul 5, 2022 | 07:16 PM
  #41
Whilst inspecting, I noticed the hardy disc to have massive tears in them. I decided to replace both the front and rear disc at the same time. That does not look good, and I didnt want a flying propshaft. I thought it would be a job for 2 nights, but instead it almost took me all week. Doing this with jack stands, trying to put power on your ratchet in weird angles didnt work out so well for me. I took my time, let my body rest in between but finished the job in the end.
Glad to have it done, another "peace of mind" job done on the list!
Definitely needed replaceing!
Fresh new bolts always look good (work in progress shot)
Old Jul 6, 2022 | 01:29 PM
  #42
First part of replacing the engine mounts, replaced the standard transmission mount with a Meyle HD mount, which should be a little bit more ruggedized compared to OEM
Old Jul 6, 2022 | 01:32 PM
  #43
Replaced a mega rusty exhaust clamp (the bolt was totally rusted) with a brand new one. This is the clamp near the secondary cats.
Old Jul 6, 2022 | 01:33 PM
  #44
As part of regular maintenance, a bottle of LiquiMoly injection cleaner. On the left the old hardy discs
Old Jul 6, 2022 | 01:35 PM
  #45
Replaced the rear droplinks with new ones. They were due for replacement and makes the rear a little bit tighter again
Old Jul 7, 2022 | 09:17 AM
  #46
Changed all 16 spark plugs with Beru UPT14P spark plugs, they were gapped at 0.75mm and I adjusted them to 0.8mm as per factory spec. So far they are doing good
Something doesnt look right...The threads are way too dirty. Looks like a gasket leak (and it was!).
Old Jul 8, 2022 | 02:08 PM
  #47
One of the previous owners scraped something, which damaged the V-bands on the catback (center resonator delete). It resulted in a small leak on both V-bands, so I fixed that with 2 new V-band clamps
Old Jul 8, 2022 | 02:12 PM
  #48
Replaced the cabin filter with a Mann FreciousPlus filter, which filters pollen, neutralizes smells, but also has anti-bacterial features
Old Jul 8, 2022 | 02:14 PM
  #49
Removed the K&N filters and replaced them with OEM filters. I prefer the filtration over a little bit more throughput
Old Jul 8, 2022 | 02:25 PM
  #50
Went to work on replacing the rocker cover gaskets, which was as tedious as everyone says it is. Dont want to do this chore more than I need to, so I bought the Mercedes sealant. Also, this was very hard to extract! I was able to MacGuyver something, which made it way more easy. Leaking solved!
1x 18mm Deep socket
1x Small ratchet extension
1x Kit gun (see pic below)
The deep socket and small extension allow you to use a proper kitgun, which was a godsend With this method, you dont need the provided black tube. You can see it on the last picture (in the back of the frame)
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
