Gear Selector Module
Old Feb 20, 2023 | 08:11 AM
Ian.cross's Avatar
2005 CLS55 AMG, 2006 Range Rover Sport Autobiography
2005 CLS55 AMG
I'm having problems with gear selection, the fault codes are pointing to a faulty Electronic Selector Module.
Does anyone know if these are coded to the car or will a replacement be plug and play?
Old Feb 20, 2023 | 05:50 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Which part are you referring to?
Old Feb 21, 2023 | 12:44 AM
Ian.cross's Avatar
Hi, its the electronic module that is part of the gear selector lever. The one that tells the ECU what gear has been selected, it's inside part no A2112674424
I believe this is the one.
I'm getting fault code P1856 and P0705.
thanks
Old Feb 21, 2023 | 10:27 AM
Unfortunately I dont know for sure, but best guess is that you can swap it out no issue
Did you do any maintenance on the gearbox? Swap out a conductor plate etc?
Old Feb 21, 2023 | 11:16 AM
konigstiger's Avatar
'71 Pinto
I believe this is the one. I'm getting fault code P1856 and P0705.
Normally plug & play when replacing with same part # any problems you will need to delete stored fault codes. Provide VIN if you want part # confirmation. Before replacing you can inspect internal board for defects that may be repairable depending on your skill set.
Posted by another member:
See attachments for replacement.
File Type: pdf
File Type: pdf
Old Feb 22, 2023 | 03:56 PM
Thanks for posting this!
Old Feb 24, 2023 | 08:46 AM
Ian.cross's Avatar
This is great info, thanks very much. I'll take it out and inspect for any obvious problems on the board.
My problem only seems to occur if the gear lever is operated many times on a journey when pulling up at junctions etc.
Old Feb 24, 2023 | 01:32 PM
JamesMBZ's Avatar
1990 500SL, 1990 560SEC, 2010 ML63, 2007 SL550
Module repair
Can anyone refer a good module repair company that I can send the shifter for solder repairs? I'm not very good at soldering.
Thanks in advance,
James
Old Feb 24, 2023 | 04:48 PM
Ian.cross's Avatar
Thanks in advance,
James
I haven't used them but found these guys who have good reviews: ecutesting.com
Old Mar 16, 2023 | 04:47 PM
Ian.cross's Avatar
This repair seems to have worked for me. I stripped the unit down, couldn’t really see any bad solders as they are so small.
So I gave the components a wiggle and one of the LED gateways popped up, two of the solders gave way so they must have been cracked.
I re-soldered them, put everything back together and all has been working ok since. Fingers crossed that’s it sorted.
thanks for the advice @konigstiger
