2005 C219 CLS 55 AMG - 722.6 5G-TRONIC TRANSMISSION SLIP AND WHINING NOISE
I bought a CLS 55 AMG 2 months ago. This week, without any particular signs, a problem arose that the car produces a transmission error after driving about 10 km. It starts to slip in the current gear, and then the transmission is no longer engaged. After a reboot, everything is fine for a while, then it starts all over again. Furthermore, a strange sound appeared along with it, similar to the screeching of a compressor. The car produces the following error codes (P0730 or P2560 or P2069). I checked the oil level with a dipstick when the engine was running after driving 10 km, and I think there is a lot of fluid in it compared to the mark. The stick must be the right size, it showed perfect results when measuring another 722.6 shifter. The liquid does not look or smell burnt. The car had a complete gearbox change at the end of 2015 in Switzerland by the previous owner (in the attached pictures), at which time it had 185,000 km. The car currently has 230,000 km on it, so the new transmission has run 45,000 km. I don't want to believe that it would have a mechanical fault after traveling such a distance. I removed the TCU unit located on the right side of the interior, and I found no traces of oil leakage either in the line or in the connectors. I will take it to a mechanic next week, where the bottom cover will be removed, I will tell him to look at the connector there as well. What can I expect? Can a control unit change and a fluid filter change solve the problem? Has anyone had a similar problem that they solved relatively easily. I would not like to go into a gearbox exchange, given the low running condition of the current gearbox. This is also why I chose the 55 AMG, because based on the opinions on the forum, I came to the conclusion that it is much more reliable than the 63 AMG engine and transmission. The car has not been neglected at all, it can be said to be in perfect condition and its entire history can be traced with all invoices.
Attached the pictures and a video. The noise -------->
Thank you!
Szilárd
https://www.youtube.com/watch?v=RaTmD1btJjA
Thank you the reply. I tried earlier - before the actual problem - this method (first in the video). I will try again, and if it not work, i try the second.
I replaced mine last year when it had about 190.000kms on the clock. it seems it had the original one. More pics in my build thread (see signature)
If I need to buy a new TCU unit or conductor plate, would any part for the 722.6 transmission be fine, or does the AMG require a special part?
Is there any other not too complicated solution? Instead of conductor plate and TCU. For example, a solenoid problem due to a broken spring? If the oil pump were bad, could it show intermittent operation? How complicated is it to replace the pump? I still don't understand it all, there are 45,000 km in the transmission...
Thanks for the helpful comments so far!
it is 100% a bad o-ring on your solenoids, a clogged screen within the valve body and maybe one of the speed sensors on the conductor plate has failed. You literally need 2 tools. 7mm socket to remove the nut in center on connector and a 30 torx to remove transmission pan and valve body.. it may take a couple hours if it's your first time but definitely a do it yourself job.
you mentioned the oil seemed to warm up fast and that the transmission was previously replaced.. if so there is a possibility the torque converter wasn't put back unto the transmission housing all the way to engage the oil pump tabs because it may feel like it's all the way on when reassembling but if the 2 grooves for the oil pump don't properly align then it doesn't go all the way on. This could actually break the oil pump tabs when tightening the transmission back to the engine. The car will still work but the oil would be hot which causes the O rings to fail faster than usual resulting in no movement. Also the broken oil tabs can be chewed up over time and the metal fragments block the tiny screens inside the valve body..
here's what to do . Disconnect one of the oil cooler lines coming off the transmission and start car briefly just to see if you have good oil flow to verify pump is working. If pump is bad then you need to remove and disassemble entire transmission to replace the inner gear of the oil pump. If oil pump is good, then you simply need to clean the valve body, and change the orings on the solenoids. Sometimes the speed sensors on the conductor plate can just be wiped clean and they will work again but they are so cheap at around $50 it's not worth the effort putting the dirty conductor plate back in the car. So before you do anything else order yourself a cheap conductor plate kit $60 on ebay(comes with the new oil filter and plug) and get a set of o rings $15 on ebay. Clean the 4 little screen filters inside the valve body and reinstall it..
Thanks for the tips. All I did today was check the connector. I pulled it apart, it was quite oily. After removing the plastic covers, everything looked good to the eye. I cleaned the connector and put it back. The situation is unchanged. Although I drove quite a few kilometers today. The sound appeared sometimes, but disappeared for a while after the car was restarted. There were no other problems or error codes with the car today, although I didn't drive it much, but I drove it a lot in one place and checked the level several times. The oil level is on the lower line of the 80 degree mark after a warm run, so it's good. When the sound appears under the same conditions, the oil level seems very high. I didn't have time for anything else, next week I will continue with the suggestions you wrote (oil flow in the cooler, conductor plate cleaning, replacement of solenoid o-rings). If there is new news, I will report immediately.
Update? Did you ever have any more transmission problems?
More info: https://mbworld.org/forums/c219/8443...ml#post9015803 (keep scrolling to see the aftermath)
