my navi is behind
Old Mar 24, 2005 | 02:09 PM
360_iti's Avatar
W203, W211, W219, W212
my navi is behind
My navi is about 200-300 feet behind the actual spot where i'm at. Is this normal ? if not, is there any way to fix it ? I've calibrated my system with the new tires and everything.
Also, if anyone is kind enough to copy (not sure if this works) a 2005 or 2004 Navi #2 (colorado) CD for me, I'd really appreciate. I'll pay of course.
Thanks !!
Old Mar 24, 2005 | 02:57 PM
Jedi Esq's Avatar
calibrated with new tires??? what is that? lol. i just got 4 new tires on my c55 and twice already my navigation has gone haywire just as yours has. what do you mean by calibrate it with the new tires? is that something we are supposed to do when we get new tires? thanks.
Old Mar 24, 2005 | 07:19 PM
360_iti's Avatar
when you go to the navi setting menu, there's an option called "calibrate" and u're supposed to put your tire size. thats what i did.
Old Mar 24, 2005 | 07:49 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
I doubt that it is ever dead on the money, but it is not far off at all. Mine shows a little off at times, but not enough to worry about.
Old Mar 24, 2005 | 09:59 PM
epbrown01's Avatar
2003 BMW 325i/z4 2.4i
Satellite navigation is supposed to be off a little, so it can't be retrofitted for weapons targeting by hostile interests. Only military units are dead-accurate. This was true even before 9/11. I've used GPS systems with my laptop and this came from Garmin, I believe.
Emanuel
Old Mar 24, 2005 | 10:37 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
200-300 feet, that's about right. All Navigations I have or used (MB Comand, Toyota Nav., PDA GPS, Honda Nav.) are within this range.
Old Mar 25, 2005 | 07:57 AM
360_iti's Avatar
k then, thanks. over and out.
Old Mar 27, 2005 | 08:00 AM
TNStangman's Avatar
The GPS unit uses two methods, one is a GPS position signal that it acquired every 5 or so secs, the other method is dead reckoning. By knowing your last GPS location the direction you were heading, the speed you are going at and a gyroscope for angle it can keep the little icon moving between GPS signals. I found on mine it seemed to be off a little like yours, I would already have passed a road but on the GPS I was just getting to it. I went into the calibration screen and fudged my tire size from 225/45/17 to 225/51/17 and now its pretty accurate.
Old Mar 27, 2005 | 09:04 AM
360_iti's Avatar
Thanks I'll try that. the other day i put 265/30/19 (rear) instead of 235 (f) and it was way off, like it showed that i was driving on another road that was parallel
Old Apr 9, 2009 | 11:45 AM
malahhaor's Avatar
06 Carrera4
Hi guys, i know this thread is old but maybe someone still can tell me. I'm trying to calibrate my Nav and i'm puzzled as to what to do after i enter my tire size, there is no OK or Done button or anything.
Old Apr 10, 2009 | 11:16 AM
john89011's Avatar
MB C32 AMG
I believe you just push in the right know just the way you use Navi if I am correct, can't remember
Old Apr 10, 2009 | 11:19 AM
malahhaor's Avatar
06 Carrera4
Right to enter the numbers, but after you enter them.... what then?
Old Apr 10, 2009 | 11:20 AM
john89011's Avatar
MB C32 AMG
ok i am gonna go to my car and check be back in a min
Old Apr 10, 2009 | 11:58 AM
john89011's Avatar
MB C32 AMG
press the right rotary button in for 2 secons and it should take you back to the main menu.
Also, here's a link to online Navi manual: http://home.earthlink.net/%7Ephdwebs...and_manual.htm
Old Apr 10, 2009 | 04:26 PM
malahhaor's Avatar
06 Carrera4
Thank you! I will try that after work. thanks for the manual link as well.
