How screwed am I
Old Mar 31, 2005 | 10:20 AM
  #51
360_iti's Avatar
W203, W211, W219, W212
hey knepster dont u have anything to say ?
u started this..
anyway keep discussing guys, im paying attention
Old Mar 31, 2005 | 10:32 AM
  #52
CynCarvin32's Avatar
Mercedes Benz
Originally Posted by 05C55
I'm not spinning anything. And for the record, the C-classs Manual which you refer to does not even list the C55 does it? The C-class compression ratios range from 8.7 on the C230 to 10 and 10.5 on the 320 and 240 and 11:1 on the C55. MB puts the same disclaimer on everything they produce regardless of the compression ratio.
that may be due to the fact that anything over a ratio of 10:1 normally requires premium fuel. If the computer is set for that grade fuel and timing is such that less oct can be problematic then you should use that grade fuel.
You also need to remember that a kompressor raises the actual compression ratio a great deal with boost. This is why kompressor cars and turbo cars are very prone to issue with low grade gas. Cars like hte ford lightning and the Saab Aero do not function well with 91 oct gas. They knock on a daily basis are really need 93 oct gas.
Old Mar 31, 2005 | 11:03 AM
  #53
Kar don's Avatar
Mercedes-Benz
Improviz and 05C55,
The childish insults and personal attacks need to stop immediately. This is your first warning.
