How screwed am I
It's fine to play it safe side but I would be highly surprised if he notices any change at all.
1) I used to fill up my E-class rentals all the time with 89 oct. gas for a good 2-3 weeks with no problems
2) The car, unless changed to "performance", is in a default fuel setting that accepts at a minimum a 89 octane fuel rating..
So, relax, sit back, and enjoy life...your car will be fine..
Here's what my manual has to say (I duplicated their boldface font as well):
Caution!
To maintain the engine's durability and performance, premium unleaded gasoline must be used. If premium unleaded is not available and low octane fuel is used, follow these precautions:
- have the fuel tank filled only partially with unleaded regular and fill up with premium unleaded as soon as possible,
- avoid full throttle driving and abrupt acceleration,
- do not exceed an engine speed of 3000 rpm, if the vehicle is loaded with a light load such as two persons and no luggage,
- do not exceed 2/3 of maximum accelerator pedal position, if the vehicle is fully loaded or operating in mountainous terrain.
It goes on to say:
Damage or malfunctions resulting from poor fuel quality or from blending specific fuel additives are not covered by the Mercedes-Benz Limited Warranty.
Road & Track also discussed octane ratings here:
Porsche Octane
I am the happy owner of a 1995 Porsche 993, which I recently purchased. Per the owner’s manual, recommended fuel is 93 octane, yet in the San Francisco Bay area, all I can find is 91 octane. I asked a local Porsche repair shop for advice, and to paraphrase what I was told: “The factory found out the cars can’t really burn high octane gasoline properly. Therefore, we recommend using regular gasoline (87 octane), which will keep the car running cleanly.”
At first I accepted the idea, but now I’m nervous about it. I do recognize the anti-knock sensor will help, but even then the manual says use a minimum octane of 90. I also recognize that excessive octane is useless, but shouldn’t the highest octane rating for an engine also produce the highest power? Even more important, as the 993 has plenty of power for my taste, is there potential for damage to pistons/cylinder walls, etc., using 87 octane? I’m sticking with 91 until I get your reply!
Joe McPeak
Walnut Creek, California
Answer:
We’d trust the owner’s manual more than the local expert, especially when it comes to a minimum octane rating. What Porsche is telling us via the owner’s manual is the car runs best — makes maximum power — using 93 octane fuel. In other words, octane higher than 93 is unnecessary and, as you point out, won’t do any good.
The manual also says the minimum octane is 90. While there could be any number of reasons the engineers selected this as the minimal rating, we can make a relatively safe assumption that 90 octane is the lowest anti-knock rating the knock-sensor and engine-management system can reliably accommodate by reducing ignition timing and thus also horsepower.
There may even be a slight safety margin built into the minimum octane rating to account for environmental conditions (extreme heat), but in any case 90 octane is what Porsche says is the lower limit, and, yes, power will likely be reduced when running that fuel. Clearly, 91-octane premium fuel, the highest octane commonly available in California, meets that minimum requirement.
Now, under favorable conditions — average temperatures and light-duty driving — you can likely get away with 87 octane. But if the temperature rises or you put your right foot down, 87 may not be enough to avoid pinging. This could lead to engine damage over the long haul.
Finally, considering the investment you have in a 993, why quibble over what — in this price range — is a few dollars’ worth of fuel? Assuming 15 mpg and 10,000 miles driven a year, the annual difference between $1.40/gal. regular and $1.80/gal. premium is $266.80. Given the peace of mind, better performance at full throttle and extra detergents in premium fuel, we’d reach for the 91-octane pump.
its an 11.0:1 compression engine, who in their right mind would use mid-grade in such a high compression engine. a mistake is ok, just drive with caution and refill asap to dilute. but, using mid-grade as a regularly accepted practice is stupid and will only damage the engine over the long run.
I disagree based on years of personal ownership of twenty or more high performance cars and motorcylces, Corvette, Porsche, BMW, Mercedes, every serious SS litre bike and MX bike produced in the last 6 years, that octane rating has adversely affected anything I have driven. I do use mid grade, but admittedly I have been filling at Costco and using premium but I am not stupid and my car does not knock.
If you are going to quote scripture in your sig, it would be nice if you did not openly call people stupid. I do not believe you actually have the knowledge or experience to back up the claim that prolonged use of 89 oct will damage an AMG motor.
Caution!
It goes on to say:
It seems pretty ludicrous to argue that the manufacturer would needlessly insist upon the usage of premium unleaded, provide detailed instructions as to how to drive if low octane fuel is inadvertantly put in the car, *and* would also state that engine damage as a result of poor fuel quality is not covered by the warranty, if using low octane fuel were in fact harmless.
As the tech page at Road & Track stated, when it comes to octane rating, I'd trust the owner's manual.
Caution!
It goes on to say:
The fact that your engines didn't disintegrate neither proves that you did not have detonation (in fact you can have inaudible pinging in an engine), nor that they did not suffer detonation-related damage...and I don't believe that Mercedes is involved in the oil/gasoline sales or distribution business, so I doubt that any profit motivation is involved...nor do I believe that they would go to such lengths to warn against potential engine damage if there were no chance of it happening.
And you have yet to produce any documentation showing that lower-octane fuel doesn't hurt performance or raise the potential for engine damage in a high-compression motor, which is because no such data exists; it is a fact, not opinion, that high compression motors require high octane fuel, period.
Gasoline faq, including data on compression ratio and octane:
Definition of octane and its relation to compression ratio:
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
The 5.5L AMG V8 is a high compression motor. Period.
Stop spreading disinformation, and get informed. You're as wrong as wrong can be on this matter.
On modern engines with sophisticated engine management systems, the engine
can operate efficiently on fuels of a wider range of octane rating, but there
remains an optimum octane for the engine under specific driving conditions.
Older cars without such systems are more restricted in their choice of fuel,
as the engine can not automatically adjust to accommodate lower octane fuel.
Because knock is so destructive, owners of older cars must use fuel that will
not knock under the most demanding conditions they encounter, and must
continue to use that fuel, even if they only occasionally require the octane.
If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away. If you are
already using a fuel with an octane rating slightly below the optimum, then
using a higher octane fuel will cause the engine management system to move to
the optimum settings, possibly resulting in both increased power and improved
fuel economy. You may be able to change octanes between seasons ( reduce
octane in winter ) to obtain the most cost-effective fuel without loss of
driveability.
Once you have identified the fuel that keeps the engine at optimum settings,
there is no advantage in moving to an even higher octane fuel. The
manufacturer's recommendation is conservative, so you may be able to
carefully reduce the fuel octane. The penalty for getting it badly wrong,
and not realising that you have, could be expensive engine damage.
The effect will be for the engine's ECU to dial back ignition timing, which means that the spark in the combustion chamber will not occur at the optimum time, which will affect both performance *and* economy, as is discussed in the portions of the FAQ you chose *not* to quote, even though they were more pertinant to our discussion than the one you did. Frankly, I think what you are doing here is kind of sneaky, in that you are deliberately omitting information which would be informative to your fellow AMG owners rather than concede that your original assertions were incorrect. Case in point: you selectively quoted data from the gasoline faq . You quote question 6.13, but do NOT quote from the very next item in the faq, which is far more pertinant to what you're trying to argue:
Not if you are meeting the octane requirement of the engine. If you are not
meeting the octane requirement, the engine will rapidly suffer major damage
due to knock. You must not use fuels that produce sustained audible knock,
as engine damage will occur. If the octane is just sufficient, the engine
management system will move settings to a less optimal position, and the
only major penalty will be increased costs due to poor fuel economy.
Whenever possible, engines should be operated at the optimum position for
long-term reliability. Engine wear is mainly related to design,
manufacturing, maintenance and lubrication factors. Once the octane and
run-on requirements of the engine are satisfied, increased octane will have
no beneficial effect on the engine. Run-on is the tendency of an engine to
continue running after the ignition has been switched off, and is discussed
in more detail in Section 8.2. The quality of gasoline, and the additive
package used, would be more likely to affect the rate of engine wear, rather
than the octane rating.
This is also addressed in question 6.16, which you also did not cite:
If you use a fuel with an octane rating below the requirement of the engine,
the management system may move the engine settings into an area of less
efficient combustion, resulting in reduced power and reduced fuel economy.
You will be losing both money and driveability. If you use a fuel with an
octane rating higher than what the engine can use, you are just wasting
money by paying for octane that you can not utilise. The additive packages
are matched to the engines using the fuel, for example intake valve deposit
control additive concentrations may be increased in the premium octane grade.
If your vehicle does not have a knock sensor, then using a fuel with an
octane rating significantly below the octane requirement of the engine means
that the little men with hammers will gleefully pummel your engine to pieces.
You should initially be guided by the vehicle manufacturer's recommendations,
however you can experiment, as the variations in vehicle tolerances can
mean that Octane Number Requirement for a given vehicle model can range
over 6 Octane Numbers. Caution should be used, and remember to compensate
if the conditions change, such as carrying more people or driving in
different ambient conditions. You can often reduce the octane of the fuel
you use in winter because the temperature decrease and possible humidity
changes may significantly reduce the octane requirement of the engine.
Use the octane that provides cost-effective driveability and performance,
using anything more is waste of money, and anything less could result in
an unscheduled, expensive visit to your mechanic.
Most people know that an increase in Compression Ratio will require an
increase in fuel octane for the same engine design. Increasing the
compression ratio increases the theoretical thermodynamic efficiency of an
engine according to the standard equation
Efficiency = 1 - (1/compression ratio)^gamma-1
where gamma = ratio of specific heats at constant pressure and constant
volume of the working fluid ( for most purposes air is the working fluid,
and is treated as an ideal gas ). There are indications that thermal
efficiency reaches a maximum at a compression ratio of about 17:1 for
gasoline fuels in an SI engine [23].
The efficiency gains are best when the engine is at incipient knock, that's
why knock sensors ( actually vibration sensors ) are used. Low compression
ratio engines are less efficient because they can not deliver as much of the
ideal combustion power to the flywheel. For a typical carburetted engine,
without engine management [27,38]:-
Compression Octane Number Brake Thermal Efficiency
Ratio Requirement ( Full Throttle )
5:1 72 -
6:1 81 25 %
7:1 87 28 %
8:1 92 30 %
9:1 96 32 %
10:1 100 33 %
11:1 104 34 %
12:1 108 35 %
Modern engines have improved significantly on this, and the changing fuel
specifications and engine design should see more improvements, but
significant gains may have to await improved engine materials and fuels.
You could save a lot of pennies on cars too, by not buying Mercedes...
What's the saying, penny wise and...
you saved a few bucks when u bought gas. how about a cookie? all that money you saved is enough for a nice big freshly baked cookie. Yummy11:1 compression needs 91 oct gas. Good thing you dont have a kompressor car. that thing would just LOVE low oct gas!
The original question was, will low grade damage the motor? My answer was and is no. I believe that even with prolonged use it wil not damage the motor. You do have valid points regarding efficiency and I don't blame anyone for adhering to the owners manual, but Mercedes is not a charity, they are profit motivated and there is a plethora of CYA in everything they do.
You can put rocket fuel in as far as I'm concerned. Mid grade is fine for the wife's BMW and I won't hesitate to use it in my C55.
