My new EVOSport headers!
here's what Im talking about:
http://www.jpperformancellc.com/mb.html
your headers look awesome though!! Do they have the ceramic coating?
You had your computer reflashed? What did it cost? I have the Evosport stage 1 with the SL55 intake I had no idea there was a stage two reflash.
Can't wait to hear what you think of them after you get them installed. I had contacted JP performance some time ago about the gains, I think they quoted 30 HP on Vadim's car without any mods.
T
T
Aaron had his coated with a different coating. In production it will be HiTemp titanium.
Typical install is six hours.
SRT6 is based on R170, previous SLK. Headers are different from C-class to SLK. They will not fit.
vadim, will you guys make headers for the slk 32 amg ?? and i was also wondering if the pump used in your e55 cooling upgrade will fit on our cars ??
As far as cooling upgrade. There is no room to add a secondary heat exchanger up front. However, we can make a kit to install bigger pump on C32. Pump should be worth some temperature drop.
Supercharged engines just don't benefit as greatly as N/A engines do because the supercharger's pressure acts to force any remaining exhaust gasses out of the cyllinder.
Obviously the C32's engine isn't at 100% VE, so some improvement can be made with headers ... and probably more improvement still with long-tube equal length headers. (Not that they would actually fit, just in theory.)
Adrian~
Give me a day to get a price quote and I will make a separate post on this topic.
SaabTuner:
C32 engine is way over 100% due to the kompressor. In our testing we have not seen any difference in power curve between equal length and unequal length. A significant increase in cam timing would make the theoretical difference be more apparent in real world.
How far above 100% are we talking? Beyond 111% VE (533 cc's + 59 cc's combustion space) the exhaust begins to suck intake gasses. If you go beyond this, there could be "problems".Was there any testing with long-tube headers? They'd need to be fairly long to make use of the first scavenging wave.
Adrian~
Less pumping losses, and less heat, but only a small addition in power.
But, with less heat, you can tune more aggressively ... so you can get more power with pullies and an ECU upgrade. It suddenly comes together.
Adrian~
p.s. (I'd still love to see what the effect of long-tube headers is on EGT.)
