Renntech Springs
Old 04-23-2005, 11:25 PM
ardy6931's Avatar
c32
Renntech Springs
Don't know if you guys have blown this topic up before or not, but if that be the case i apologize in advance.
I wanted to know if anyone had just renntech springs added to their cars. How much does this lower your car and how is the ride and handling compared to its stock settings. Please advise.
Old 04-23-2005, 11:53 PM
cayo71's Avatar
C32 AMG
Question On the same line
Is it required to change the shocks to avoid getting a "boucy-reboundy? Car?
Thanks!
Old 04-24-2005, 01:54 AM
ardy6931's Avatar
c32
Renn tech spring owners, I have looked at several images of people that have installed the renntech springs. It looks like the tail sits a little bit higher then the front. How is the overall handling and comfort level so far compared to your stock settings? What did you purchase from renntech to complete your mod.
Any regrets about getting them?
Old 04-24-2005, 03:21 AM
BenzoAMGpower's Avatar
Cars and boats!
if u want the rear lower then get the 9mm spring pads for the rear in combo with the RENNTech springs. The springs r rated for the OEM AMG/bilstein shock rate so no change of shock is required. I am overall very satsified with mine. Ride quality is not lost, handling is improved, no more understeer, and more aggressive stance!!
Old 04-24-2005, 12:15 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
So, this is the cheapest way to lower our cars without buying the shocks, right?
Canyou post the part number for the Renntech springs and the pad numbers (front and rear) for our information / reference, thanks.
Old 04-24-2005, 12:38 PM
AMGod's Avatar
Just get Vogtlands. IMHO, they are better matched to the shocks than the Renntechs. Had Renntechs on my other C32. They are less than half the price of Renntechs. They have been making springs in Germany for 90 years. Good to have options.
Vogtland Springs
Old 04-25-2005, 10:00 AM
360_iti's Avatar
W203, W211, W219, W212
Ardy, I think all of these are based on the assumption that you're driving solo, or at least no passengers in the back, otherwise you might have rubbing issues, also depends on the wheels.
Old 04-25-2005, 03:16 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
AMGod, you seriously going to compare Renntech springz with Vogtland springz? Vogtlands are a cheaper alternative but Renntech is the way to go in terms of looks and performance....
Old 04-25-2005, 04:13 PM
Cars and boats!
see for yourself... this is my car sitting on renntech springs and 8mm rear pads!!!
Attached Thumbnails Renntech Springs-img_2775.jpg   Renntech Springs-img_2781.jpg   Renntech Springs-img_2766.jpg   Renntech Springs-img_2757.jpg
Old 04-25-2005, 04:45 PM
360_iti's Avatar
Looks good. imho this is what it supposed to look.. the front and rear wheel gaps are about the same !
Old 04-25-2005, 04:52 PM
MBworld Guru
FrankW's Avatar
white and whiter
yea, i'm on RENNtech springs and running 18s atm too and that's how it looks except mine's black.
Old 04-25-2005, 04:56 PM
psk145's Avatar
2006 E55
how many dots are the 8mm pads?
Old 04-25-2005, 06:22 PM
Harris's Avatar
If you are thinking of changing the springs only, IMO, Renntech springs are best matched with the AMG shocks.
Old 04-25-2005, 11:53 PM
ardy6931's Avatar
c32
Looks perfect man, thats exactly what I want my car to look like. And those rims, damn those are hot. How much those run you? I might have to get me some of those . I just got a bunch of parts in wing, roof wing, expression grille, and now I have to go europe for a month. Its torture.
WHen I get back I will get the renntech springs and 9mm pads as you suggested. Thanks for the pics, it broke the camels back
Old 04-26-2005, 12:33 AM
Ultraman's Avatar
Any rubbing issues if you have 2 adults sitting at the back?
Old 04-26-2005, 01:04 AM
AMGod's Avatar
I've had both and prefer fronts with Vogtlands with stock springs on back with an H&R rear bar set on stiff. The Vogtlands match the valving of the stock shocks better than the Renntechs, IMO. My other C32 had Renntechs with 25K miles on it. My current C32 has 18K miles on it. The driver aids kick in much less with the current set up. Price for parts is irrelevant regarding my personal selection criteria. Performance is everything.
Old 04-26-2005, 01:41 AM
Cars and boats!
no rubbing at all with 3 fat ***** sittin in the rear and a trunk full of luggage
... I just got my camber kit, going to install it this weekend, I just hope it wont rub with a corrected camber!!!
Old 04-26-2005, 09:11 AM
Ultraman's Avatar
Is camber kit "must have" when you install the Renntech springs only?
Old 04-26-2005, 05:00 PM
Cars and boats!
its not a must have unless you do a lot of drag racing like i do and like minimal camber!!! A little camber is good for handling but the camber kit will allow me to correct any negative camber when i go to the drag strip. Any lowering spring or coilover setup will give you camber!!!
Old 04-26-2005, 05:07 PM
Ultraman's Avatar
I see, thanks. All I want is just lowering the car a little bit in order to make less gaps on the front fender gaps. I believe I would lower my car as you did, using renntech springs and 9mm pads. This is the cheapest way to modify my car instead of buying shocks and springs together.
Old 04-27-2005, 01:54 AM
smgC32's Avatar
Buy the Renntechs. BTW, Bilstein does not make the stock struts/shocks. For comparison, what is the spring rate for the Vogtlands?
Old 04-27-2005, 03:16 AM
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
Do you just go to the dealership and ask them for the spring pad?? Or is the person on the otherside of the counter going to look at me strange and they what are you talking about.
Old 05-03-2005, 12:32 PM
jtc55's Avatar
08 E63
do you have any pics of your car w/ Vogtlands on them. thanks
Old 05-06-2005, 05:35 PM
cayo71's Avatar
C32 AMG
Thumbs up Well
I just had mine installed and I like it a lot. I can't say about Renntechs but the Vogtlands that I got from Purems didn't change much the ride quality and lowered my front end 1.6 Inches. I'll post pictures soon.
Old 05-17-2005, 10:21 AM
cayo71's Avatar
C32 AMG
Pictures
Here they are. Waiting for my 18''s now.
Attached Thumbnails Renntech Springs-benz-003_mini.jpg   Renntech Springs-benz-010_mini.jpg
Quick Reply: Renntech Springs
