SL55 intake kit for C32
'14 428i M-Sport, '02 C32 AMG
i see so the sl55 front engine cover will fit with modification like gluing, but is not a direct bolt-on. the full sl55 intake itself is full bolt-on tho. so you can run the full sl55 intake and airboxes without using the sl55 front intake cover easily, without modifcation?
2004 Capri Blue C32
I don't even have my C32 engine cover on there with the SL55 air boxes installed. I don't have any problems without it. Should I expect some? By the way, I have an Escort GT2 timer (similar to GTech) and before putting the intake kit on a few months ago, my best 0-60 was 5.47. Yesterday I did a 5.17 and this weekend I plan to install my ASP pulleys. I hope to get it down below 5.0 before I take it to the track and see what the real numbers are.
W203, W211, W219, W212
E55, C32, ML320
The cover is primarily for looks. You can leave it off. The stock C32 cover looks out of place and doesn't fit well afterwards. I used duro cement glue and pull the cover on and off all the time without any problems.
#32
02 C32 AMG; 06 Subaru Legacy Wagon
thank you for the info 5150_c32. as far as my e36 m3, i didn't have much on, just acs type iii wheels, uuc exhaust, some basic stuff, nothing special. how about you?
#33
like the other posts stated, you CAN get these parts from the dealer.
you do not need to run the cover, I don't.
it is also very easy to switch back to stock when visiting the dealer, so keep all your stock parts in tact.
#34
2004 Capri Blue C32
Originally Posted by jt316
thanks blando, I will look for it.
jayitx: I have the same timer, my best 0-60mph is 5.03s on 30C day, stock.
#35
C32
Maybe I don't have much tire spin off the line, that's why my time was better.
better tires (I use PS2, not the best but good enough) and spacers(I use 15mm on my rear tire) would help.
#36
2004 Capri Blue C32
I'm still playing with it, but not really too concerned since I don't really race it. I'm sure I'll get better times if I keep at it. I just like to be faster than other cars on the highway!
I use Toyo T1Ss on all 4 wheels, with 255s on the rear. They don't seem to spin nearly as much as the 245 Pirelli's that came stock. No spacers though.
#38
2004 Capri Blue C32
jayitx, stock with 255 tires? any rubbing issue?
#40
c63
#42
based on the facts that 1 mile = 5280 feet and 1 hour = 3600 seconds, 0.56 second at 60 mph = 49.28 feet.
Meaning u'd be ahead by 3 car lengths.
Worth it ? I think so.
#43
Not quite. You'd actually be ahead by more if you were still accelerating.
Even so, it's still not even that simple. You have to look at the non-linear acceleration in each gear for both cars. Then, you have to figure in traction issues, driver, etc... This is most certainly not a "simple" equation. However, your numbers probably aren't that far off.
But, still, worth it, yes.
