235/35/19, 265/30/19
Old May 24, 2005 | 01:49 AM
DbleNckel's Avatar
05' MB C-dblenckel
Question 235/35/19, 265/30/19
those w/ this tire set-up, what are you guys/gals running for tire pressure?? and would the pressure be different if I ran 8" Fronts and 9" Rears, in oppose to someone running the same tire set-up, but running 8.5"F and 9.5"R?? ...I've done a search, but to no avail....thx for any help/recommendations...
Old May 24, 2005 | 01:57 AM
BrabusW203's Avatar
It varies slightly from brand to brand. Please refer to the sidewalls of your tire for the appropriate pressure range.
Old May 24, 2005 | 11:51 AM
DbleNckel's Avatar
05' MB C-dblenckel
I thought the same thing about various brands, but the sidewall only tells what "MAX" pressure not to exceed, but doesn't say what is recommended or what's the optimal psi......
Old May 24, 2005 | 01:23 PM
BennyZ's Avatar
RENNTtech C55
I have 8.5" and 9.5" - same size tires -
I keep them around 36 psi
BennyZ
Old May 24, 2005 | 01:27 PM
BrabusW203's Avatar
I have Toyo T1s on my 19" HRE 841s @ 38psi
hope this helps?
Old May 24, 2005 | 01:31 PM
DbleNckel's Avatar
05' MB C-dblenckel
BennyZ, Brabus;
thx for the info, question though...do you both do the same psi for both front and rear?? isn't there a variance since they're a staggered set-up..similar to the stock set-up where they recommend 33F/37R for the 225/40/18, 245/35/18???
Old May 24, 2005 | 01:39 PM
BennyZ's Avatar
RENNTtech C55
BennyZ, Brabus;
I keep them all at about 36 psi
BennyZ
Old May 24, 2005 | 01:48 PM
BrabusW203's Avatar
BennyZ, Brabus;
Have to double-check later...but last I remembered I had 38 in the rear, front should be the same but I'll bust out my pressure gauge to make sure
Old May 24, 2005 | 01:56 PM
DbleNckel's Avatar
05' MB C-dblenckel
COOL! Thx for taking the time to check for me Brabus, cuz I know it can be a pain unscrewing the hidden valve stem covers on HRE's
Old May 24, 2005 | 07:56 PM
Harris's Avatar
I have 19x8.5/19x9.5 T1-S 235/265 and I am running 36psi front and 34psi rear.
Old May 24, 2005 | 09:35 PM
DbleNckel's Avatar
05' MB C-dblenckel
you're running a higher psi for the FRONTS??? I always thought on a staggared set-up that the rears get the higher PSI???
Old May 24, 2005 | 09:48 PM
Harris's Avatar
Having a bit lower pressure on the rear will give you better traction during launch.
Old May 25, 2005 | 01:19 AM
bnz616's Avatar
2012 GL550
I'm running 235/35/19 and 265/30/19 with 39 psi front and 40 psi in the rear. Hopefully the air will protect the rim when I actually do hit holes. Then again, too much air might actually cause the tire to bubble if I hit something hard enough instead. Its pretty harsh at what I have it at, but when I actually do hit holes, it feels a little more solid. I used to have it at 36 psi front and 38 psi rear.
Old May 25, 2005 | 09:33 PM
anucci's Avatar
hope this helps?
Brabus, I LOVE those wheels, any way you can post some pics?
Old May 25, 2005 | 10:28 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
It doesnt matter what size wheels, widths or tires you have. It goes by the weight of the car etc.. No matter what tires you have, even 15", you should still go by what it says on the inside of fuel door. I go 2 PSI over what it reads on that door.
Old May 26, 2005 | 08:19 PM
BrabusW203's Avatar
My current pressures are actuall 35/38.
Hope that helps. Damn was it a bizatch getting to my valve haha. o wells, no pain, no gain.
Old May 27, 2005 | 11:58 AM
DbleNckel's Avatar
05' MB C-dblenckel
thx boss for taking the time to check!! that's exactly what I set mine at too! ......I warned you on those hidden valve caps!!! :p
