No Tele-Aid error message
I called tele-aid and they told me I couldn't remove the fault. How could this be?
Anyway a 5-10 minute job via Star Diagnostics, for me.
I would guess it is no charge to you.
Problem is that "No Tele-Aid" shows up as a legitimate fault code see the fault code boxes in the lower right corner of your multi-function display. Without activating Tele-Aid, the fault code boxes will always be there, possibly masking some other fault code of more importance. Since you are used to seeing the fault code in the display, you may not realize something is really wrong.
Tele-Aid is free the first year, and cancelling is easy enough. Biggest challenge is remembering to cancel it. Plus, you can have some fun playing with it. Just to determine the limitations of the remote unlock capability is a little fun.
Mercedes will send 2 letters to you towards the end of the first year asking if you want to continue or cancel your service. So you shouldn't have to remember to cancel it.
Re: masking other fault codes.
Your multi function display should "say" 1 malfunction, when you press the arrow on the left side of the wheel it should display "tele-aid not activated".
If another fault is detected the display should read 2 malfunctions and display the tele-aid as well as the 2nd fault when you press the arrow.
I bought my vehicle with a few hundred miles on it, therefore it was considered used. According to my closest dealer, the second owner would not be entitled to a free year, even though the original owner had never activated tele-aid. The dealer again told me there is no way to get rid of the message.
BTW, I do make sure that there is only 1 malfunction, and I consider that normal now. When the "reserve" gas tank kicks in, the car considers there to be 2 faults.
Thanks for all your help, but one little problem...
All your dealer's service dept. needs to do it hook the car up to the SDS laptop and program it correctly. Your SOS button will not light and you will no longer get the fault code.
I think your dealer is mistaken. I sell MB in PA and have had people buy demos that did not have the tele-aid activated.
If it was never activated you can fill out the form and fax it in to tele-aid and get the first free year.
I also spoke with one of our techs and he confirmed that they cannot delete the error message. If you hit the reset button it will clear it but it will come back next time you start the car.
Sounds like sign up, or ignore it.
Dealer could activate/deactivate, and make a customer happy.
I don't think we would tollerate a NO CD CHANGER message if it was never installed would we?
Start squawking. Write to Benz, nothing to lose.
JustinTRW,
Re: remembering to cancel your tele-aid.
I was referring to the malfunction display in the lower right of the MFD. It does not tell you how many faults there are until you scroll the arrows, as you suggest. But you have to take this action in order to see how many there are.
Most of the people aroud here don't read their manuals to understand these functions...
This guy was interested in deleting the No Phone message
(as was done successfully on my car), apparently TeleAid is in "same" software location....
According to my local dealer, In stardiagnosis :-
Control Units -> Info. and comms. -> ICM -> Control Unit Adaptations -> Version Coding -> Optional Equipment
In the optional equipment menu you can set the following
to present or not-present depending on what you have
AUDIO, Tele-aid, Cellular Telephone, Trip Computer, Navigation
He beleives that turns on and off different menus.
Question: If the customer declines service how do we remove the "1 Malfunction" message from the IP?
Answer: The "1 Malfunction" message will always remain on the IP if the customer declines the service. Legally it must appear as an indication to the customer that the service is not activated. If you scroll down that menu, you can see it says, "Tele Aid Not Activated" if you need to clarify the malfunction message for your customer.
