Pic, 19" TSW Bremma lippage and new tread
Subscribe
Aug 12, 2005 | 08:12 PM
courtesy of Eurotek, well not courtesy but discounted of course. BTW, it was clean this am, teh installer gooed up the rim.
Reply 0
Aug 12, 2005 | 08:32 PM
Do you mind letting me know...is that the max lip you can put on there?? Could you have gone any bigger if requested?? THANKS!
Reply 0
Aug 12, 2005 | 08:34 PM
You have to ask Neal, I only sign the checks.
Reply 0
Aug 12, 2005 | 08:45 PM
WHOA! That's one big picture
Those rims look so nice, I really need a set.
Now if only I had another car to put them on...
Reply 0
Aug 12, 2005 | 08:46 PM
That is the maximum lip because the Bremmas aren't really designed to be big lip rims. Those are usually the Thruxton and the Volcano's.
Reply 0
Aug 12, 2005 | 09:04 PM
Thanks for the pic.
Reply 0
Aug 12, 2005 | 09:51 PM
Quote: Thanks for the pic.
You asked for it.
Reply 0
Aug 13, 2005 | 02:22 AM
Wow, they did goo up your rims. That sucks. Hey, looks like they also mounted your tires reverse. PS2's sidwall's have "outside" written on them to show which side should be facing out. From the pic they look reversed. Check em when you get a chance.
Paul
Reply 0
Explore
Aug 13, 2005 | 05:47 AM
Cool pic, and yes, that is the largest lip you can get on the Bremmas. They are not a custom wheel. So its that or nothing.
Doug, it also does appear the tires are mounted backwards. You will probably see on the sidewall if you look it says inside. The other side says outsude. :p Make the shop switch it for free.
Reply 0
Aug 13, 2005 | 12:14 PM
Quote: Cool pic, and yes, that is the largest lip you can get on the Bremmas. They are not a custom wheel. So its that or nothing.
I can tell from the tread pattern that they are in fact mounted properly, but I'll go check.
Reply 0
Aug 13, 2005 | 05:49 PM
Quote: I can tell from the tread pattern that they are in fact mounted properly, but I'll go check.
Wow, your "Whip" is shiney Nice wheels
Reply 0
Aug 14, 2005 | 07:12 PM
You guys were right, the left rear was installed backwards and they marred my rim. IDIOTS I'm buying my own shop. Anyone need a good shop to take their car in the East Valley, I should be up and running in a few months.
Reply 0
Subscribe
Currently Active Users (1)
