Is the C55 engine the same as the E55 (minus the SC)?
Old Aug 17, 2005 | 07:50 PM
jsaccio's Avatar
C250 Coupe, Porsche Cayenne Turbo
Question Is the C55 engine the same as the E55 (minus the SC)?
This is probably a dumb question but is the C55 engine the same as the E55? In other words, would a E55 supercharger fit a C55 engine?
Old Aug 17, 2005 | 09:47 PM
mez456's Avatar
'05 C55 Black/Black Lighting, Premium, NAV
Most likely it is the same block but probably not much more. Probably different headers and such. But I am just talking out of my a$$. I am sure someone more knowledgeable will "learn" us.
Mez
Old Aug 17, 2005 | 09:56 PM
KompressorKev's Avatar
'14 428i M-Sport, '02 C32 AMG
it's not the same motor minus supercharger. the e55's internals are different, among other things, as the compression ratio is lower.
Old Aug 17, 2005 | 11:28 PM
derrick_lui's Avatar
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
on the website it says the E55 is reinforced steel block...
forced induction engines need to be stronger...
Old Aug 18, 2005 | 01:38 AM
cntlaw's Avatar
C55AMG W203; 330i E90
I thought SL55 , E55 , C/CLK/SLK55 are all using the same 5439cc engine with different arrangement. At least SL55 500hp and E55 476hp should be the same engine.? Just curious
Old Aug 18, 2005 | 01:58 AM
E55AMG99's Avatar
1951 Caterpiller D6
Currently, C, CLK, SLK, ML 55 N/A motors are the same. E, CLS, SL, CL, S 55 Kompressor motors are the same. MB claims that installation difference between the cars cause the slight variation in power ratings like the SL and the E.
Old Aug 18, 2005 | 10:03 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
5.5L They are all M113 motors just that the S/C motor has beefier rods,different pistons,and stronger crank,with the M113 blck possibly being reinforced.
Old Aug 18, 2005 | 10:06 AM
ProjectC55's Avatar
You are correct! Same M113 motor .Just some variations perhaps in the blck for being S/C.
Old Aug 18, 2005 | 10:13 AM
E55AMG99's Avatar
1951 Caterpiller D6
They may all be M113 class engines but bolting the SC from a K motor on an N/A engine without other modifications to the internals and block will likely result in one expensive grenade!
Old Aug 18, 2005 | 12:05 PM
ProjectC55's Avatar
You'll be surprised how much power the N/A internals are able to withstand with a KLEMMAN or RENNTECH kit!
Old Aug 18, 2005 | 12:29 PM
E55AMG99's Avatar
1951 Caterpiller D6
True, it is one tough engine!
Old Aug 18, 2005 | 12:34 PM
mez456's Avatar
It's all about ball bearings these days anyway!!
Old Aug 18, 2005 | 12:36 PM
E55AMG99's Avatar
1951 Caterpiller D6
OK Fletch, if you say so!
Old Aug 18, 2005 | 01:00 PM
ProjectC55's Avatar
Here's your N/A 5.5L example with a Kleeman charger.https://mbworld.org/forums/c32-amg-c55-amg-w203/116837-kleemann-55k-s7-update-pictures-dyno.html No grenade here!
