TEIN coilover updates...
I rarely post on this board, but thought I would update you guys on the TEIN R&D for coilovers and springs.
Here's a thread that I started in the w203 boards:
LINK: TEIN COILOVERS THREAD - W203 FORUMS
Since you all are w203's as well, I thought that I would open up questions to you, if you are interested in me passing on any questions to the rep I'm dealing with over at TEIN, USA.
I know that the AMG suspension is something a lot of people don't like to mess with or change (because it's pretty good already), for those of you who are interested, please feel free to post your questions here or on the w203 forum, so that I can add that to a list of questions already posed by other mbworld.org C-Class owners.
The AMG suspension ride quality on my C55 can be deemed by some as "****ty" but the handling on it just doesn't justify the firm ride. In my mind it should handle better for how firm the suspension is but that isn't the case. The car still feels "floaty" and would benefit from a coilover suspension perhaps by lowering the center of gravity. The car would also look better by eliminating the wheel gap.
I think if TEIN came out with something similar to the KW Variant 2's there would be some interest. EDFC compatible would be a plus. I have TEIN coilovers on my other car and I don't really have any bad things to say about them.
Tein tends to release suspensions in what they consider luxury cars only in the CS series or at least launches with the CS.
Can the car be dumped on the coilovers without having to use spacers? If it requires spacers, what size?
Thanks.
Also, to add, the EDFC is only compatible with TEIN coilovers that have the Upper Pillowball mount.
Super Street/Basic Coilovers - Available for 320 and 240.
S-Tech/Super Street - In Development for 230 K (my car, but am planning on asking about the coupe compatibility as well)
SS-P - In Development (not sure if my car will be used for that as well, but we'll see. I'm highly interested in the SS-P for a simple reason = EDFC)
Now, since the current availability for TEIN parts are the BASIC's and the SUPER STREET coilovers for the 240 and 320, I don't see any reason why these wouldn't work on the C32's. Also, do any of you know if there are any differences in the suspension setup from the C32's vs. the C55's? I don't know if they changed anything, since they borrowed the CLK front end for the 55's.
I was planning on asking about compatibility with the C55's. Would all of you 55 owners like me to ask if they are interested in having someone come in for R&D on w/ the 55?
Okay, so I ended up getting my car back yesterday afternoon and I have some info to share (both good and bad).
What are the spring rates?
Front - 336 lbs/inch, Rear - 448 lbs/inch
What are the compression rates?
TBD
What are the rebound rates?
I have a pdf file that shows these rates, but I don't know how to upload this or host it as an "image". If somebody does know how, email me and I will reply with the pdf file.
What model C Classes (w203) can purchase/install the TEIN coilovers?
At this point, only the 230 K SS, 240, 320, 320 SS are good to go as far as getting these setups for both the BASIC and SUPER STREET coilovers
As for the C32's, I wouldn't be surprised if these would work for you as well since the weight shouldn't be that far off from the 320, but I would call TEIN, USA to inquire. They didn't mention whether it would be good to go. Unfortunately, this is bad news for coupe owners because the coupes have not been confirmed for either the 230 or the 320 in terms of fitment/compatibility. For those coupe owners that are interested in more information or updates on the progress with these, you can contact the rep I was dealing with, Sergio Campos at TEIN, USA.
What spring only options will be available?
S-Tech springs R&D is done for the 230 K SS. I don't know when they will have pricing available, but I've completed my part of the R&D. Now it's only a matter of time until they post them available. As far as I know, there were no snags with those (since I'm currently running on the Super Street coilovers).
Will the SS-P (SUPER STREET W/ PILLOWBALL MOUNTS) be available?
Contrary to what was indicated in their catalog, this might not be possible at this point. There's an issue with the top mount design on the C Class. I will be keeping in contact with them to see if they need my car again for more testing. This one will have to be a "wait and see" thing. Tommy, this is important for us because if the SS-P isn't going to be available/compatible, then that also means NO EDFC
Will there be any setups for the C55 (V8 engine w/ w203 chassis) AMG?
They may need a car for R&D around September. For those that are interested, please give Sergio a call and tell him that Aldrex recommended you. The current setups are not compatible with the C55.
I planning to either A) get the basic if it's comparable to the H&R coilover or B) get my friend's H&R coil when he sells the car in Oct/Nov.
With either choice I will have to change the rims.
I know that for brand new BASIC c.o.'s, they're cheaper than H&R in terms of $, but not necessarily cheaper in quality.
I've tried it on my friend's car with cupkit and it works, but go any lower than cupkit it definitely won't work unless you don't have big brake kit which you can run them without the spacers.
so yea...I might put these up to trade or sell and get something else if I go with the TEIN basic or ss.
It might be able to work without swapping out the rims, but if you intended on doing that anyway, that's cool too...But I wouldn't doubt that it would still work.
Of course it is not like we have a large selection so the coil over they build may blow our current offerings away. Hell, it should not be too dificult to build something better than the H&R's.
