Latest Project (in progress pics)
E55, C32, ML320
Back from shop pics
Car is back from shop. Sun was going down, but I took some quick pics. For all those who PM'd me, I don't have the bill yet, but should have more info soon.
W203 C240
very very very and did i mention very nice...so are all the brake mounting points the same across all MB models...front and rear? I would have thought the rears would be different but then again cost savings would dictate they'd be the same.
W203 C240
Originally Posted by ricky.agrawal
Lookin' meaty!
Have you done any runs to compare braking distance.. or fadeness (man is that even a word?)
E55, C32, ML320
Lookin' meaty!
E55, C32, ML320
#32
Originally Posted by blando
The W203s and W209s are interchangable rear to rear and front to front, but not front to rear.
hmmmm, with that said then this could work for the w210 then...can you find out please?
#33
E55, C32, ML320
#34
The W203 and W209 share the same c-class chassis and many components. The W210 is a different ballgame and I don't think it would be a bolt-on mod. If I hear anything different, I'll let you know...
thanks
#38
E55, C32, ML320
Originally Posted by rubensans
Can you post part numbers?
Will they fit the sportcoupe?
Best Regards.
Best Regards.
#39
E55, C32, ML320
Originally Posted by C55mOtiOn
That looks real nice!!
please tell us the price... thanks!
#40
E55, C32, ML320
Originally Posted by RawAMGpower
Can you also tell us the shop you got them from and where they are located incase anyone else wants to get these.
The shop/mechanic is awesome and he can be reached at mbztuner@gmail.com.
#41
02 C32R
blando, are the rear rotors the same size as the stock (they look like it since you still have the dust sheilds)? If so, then could you please find the part numbers for each side (I know you have heard this already).. Then if these are off the CLK55, you mentioned that you are looking into upgrading the fronts, are the CLK rotors the same size as ours and do they match the rears (x-drilled and slotted)?
#42
E55, C32, ML320
#45
E55, C32, ML320
Originally Posted by billybenz
looks real good
#46
E55, C32, ML320
i really want one now!!! if any sponsors can get this, just PM me... thank you!
#47
E55, C32, ML320
Some additional information I found out today: The heat shield does have to be trimmed a bit to accomodate the larger caliper and longer flex lines should be installed.
#48
07 CLS550 & 07 Accord
#49
02 C32R
I emailed the shop a few questions and never heard back... I wanted to know if the rotors from the clk55 will bolt right up to our current brake system, I like the xdrilled and slotted rotors they come with. I think the front rotors are the same size as ours, but the rears are a little larger. Does anyone know if these rotors will fit our stocks calipers??
#50
E55, C32, ML320
