Rear axle is sticking out more to the driver's side than passenger's side on my C32
2008 Ferrari 430 Scuderia, 2008 Range Rover Sport Supercharged, 2008 Mercedes-Benz S550
Hello, I have a 03 C32 and I have recently put on the Brabus Monoblock VI 18x8.5 front with 225/40/ZR18 and 18x9.5 rear with 255/35/ZR18 with 5mm spacers all around and H&R sport springs. But it seems like the rear driver's side wheel is sticking out more than the passenger's side wheel(The rear passenger's side wheel seems to be pushed in more than the rear driver's side wheel), and it result in rubbing only at the rear driver's side but not the rear passenger's side ! This had happened even before I lowered my car with my 18" Brabus wheels on it ! Can anyone tell me is this normal ? Is there a problem on my rear axle( The front seems OK ) ? What can I do ? Thanks !
what is the offset of your wheels without the added spacers?
Panel fitment tolerances are never perfect or close to it with the C Class. My front fenders were off by 4mm. Not unusual for the rear, especially if perfect offsets are not used. Roll the fenders and/or trim the flange.
Silver 2002 C32, Silver 2006 CLK 350
I have the same problem... I rub on the left side but clears the right side. I had to shave the plastic and roll the fenders. i still rub on but not as bad
Is it the rear axle causing the problem ? Can the dealer fix the problem if that is the case ?
2006 E55
mine also rubs on the left side with my HREs. Only does it with another person in the car going over large bumps or right turns.
I noticed the left side isnt as cambered as the right, so maybe this is why.
W211 E63
Originally Posted by Zeppelin
Either remove the spacers or use a 3mm in place of the 5mm on the side that is rubbing.
Correct me if I am wrong.
![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
Originally Posted by Vader13
whos the idiot who sold your brabus package..rear spacers are wrong size..
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Call Brabus...I forgot the sizes I just know the rears are different than the front, Brabus did mine onsite in Newport Beach Ca.
